Delta /Rockwell Drill Press Fix Up
Cypherian
Delaware
Hey ,
Well as often happens in my shop and I am sure others here, I went to fix up my old Delta / Rockwell drill press a bit basically clean and oil and grease along with fix the variable speed adjustment handle. Well that is where it started unfortunately I found several other problems... I went to unplug It and found the cord had dry rotted so time for a new one. I then moved on to the variable speed adjustment I had never fully run out since I drill mainly steel and such but it was always stiff to move. Found two gears of the assembly missing teeth / tooth and a few teeth with burrs from hitting at the wrong angle I presume because of the other gears missing teeth. I have searched several sites that were suppose to have parts but most only had basic stuff you could replace from a good hardware store. So I will see if someone can cut me new ones or order blanks and file to fit though they are hot fit I believe so it will be a PITA. Moving on to new cord took the box apart to do so and found not only had the outside sheath dry rotted so had the wires inside for the power cord and the wiring for the motor to the switch.. Sigh back to the hardware store for a 4 wire 12 ga cord nope they did not have any so found a dryer cord 4 wire 10 ga well close enough. Even added a goose neck light wired into come on when the drill press comes on so one small win.
If anyone has one of these presses Delta/ Rockwell model (15.000) though it appears the 15.041 and 15.042 have the same variable speed control gearing and it is totally trashed I would like the gears if you do not need them and are not going to rebuild it. Also if you have old equipment like this you may wish to check your wiring too externally it may not look bad but as soon as I moved the wiring in the box you could hear the insulation cracking and see it falling off word to the wise.
Cypher
C
Cypherian
Delaware
Well Progress So Far.
Light installed cheap Wal mart Desk Lamp some brackets and wiring and tada .. Has anyone tried a CFL in a machine light ? I am thinking about it or an LED for the drill press and the grinder.. I painted the bottom as a test with the Rustoleum Spray shown in the picture it is to light so I am told. ( Color Vision is Not Good) I am going to try the can of Darker Oil based and have it looked at to see if it is closer. I figure start at the bottom it is easier to strip the paint back off . I still need gears but I have them sync'd to allow me enough range for my normal drilling speeds for now. I need to make a frame and steal the hockey puck idea for leveling. More to come...
Cypher
nine4gmc
Dallas
Looking good, I ran a 4500k CFL in my lamp for a while until I changed presses. I need to put a light on my new one.
There is a darker color I use that should be close, I'll check after dinner and post it up for you.
C
Cypherian
Delaware
Thanks that would be appreciated since I do not see color well I have to have someone go with me or look at it after I test the color. The quart can is a darker color grey but won't get to try it for a few days.
Cypher
