Made some more progress with the DP. I picked up a wire wheel and cone for the angle grinder. It made short work of the oil and rust on the table/base. I used my drill and Dremel to get to the nooks and crannies. Then hit the whole thing with acetone. All prepped and ready for paint.
I also made a tool that Outlaw had suggested in another thread. It worked perfect for getting the name plate off.
I need to get a pressure washer just to get the grime/grease out of the head casing.
I'm restoring a very similar Delta Drill Press - DP 225. I've just got one more coat remaining on the head before I start putting it all back together. I have a couple of questions about the next steps... What parts need lubrication and what type of lubrication should I use?
Also, my tilt table scale needs to be repainted but I'm worried about using spray paint because it might fill in the lines and the numbers. Any advice? Looks like you didn't have to paint yours but I couldn't tell for sure.
Thanks guys.
Very nice! Though I am partial to 50's Delta's
I ordered the paint and some new course wire brushes. I will have to research electrolysis. Living California I need to be careful how to dispose of the byproducts.
How do I get the quill apart? There is a snap ring on the top that looks preloaded and some kind of hard to get to split ring on the bottom.
Worked on the pole last night.
I used a deburring wheel. It worked good but took forever.
That's the one.Amazing tool I learned about from The 1950s Craftsman garage page.
What model is that bandsaw? I'm looking for one and that looks to be about the perfect size. Does it cut metal? Nice drill press too! -John
Thanks Kyle, it was definitely a labor of love. It runs like new as well as looking like new. I have been debating with myself to drill holes in my workbench and lug it down. Well a couple of weeks ago we had a very small earthquake so I went out to the garage and bolted it down. Makes me feel better knowing that the kids won't tip it over on themselves too.Alex,
GREAT job on your DP restore! That thing looks new! You did such a great job of paying attention to all of the little details, which makes it truly YOUR DP. i tip my hat to you!
Oh, and now I'm on the look out for a vintage DP..![]()
Thanks Maui. $150 is at the top end that I would pay without a center pulley. Don't underestimate the hours it will take to restore a DP. I plan on keeping this DP for the rest of my life so the 6 months I spent looking and the 6 months restoring can be justified. Don't settle for a beat up one that's missing parts. Having a good working example to start with is important. Good luck finding your own and definitely let me know when you do.Alex,
Beautiful restoration job. I thought I had an opportunity to buy exactly the same drill press (but without the slow speed attachment) for $100, then the owner changed his mind. He asked $150.00 instead and I passed. After looking through your restoration I probably should have bought it.
Maui
