if you are going to keep the engine around, how about dressing it up and making a display piece out of it, at least degreasing and a little cleaning?
either way, I like what you have build with those custom cabinets and the glove dispenser is a nice feature.
Thanks for reading! The long-term plan for the motor has always been to rebuild it. But even when clean the problem is storage. It takes up more than its fair share of space in a small garage.
Are you using 3/4" baltic plywood for your cabinets? I really like how finished they look and I'm planning on starting on my own next weekend.
Where do you source your plywood from?
Looks great.
M.
Yes, it's 3/4" Baltic birch. It took a few phone calls to find someone selling baltic birch in Denver. I've been going to a lumberyard called Austin Hardwoods. I don't know the equivalent place up in Vancouver but I've seen that Rockler, Woodcraft and Home Depot sell smaller sheets. In fact, I bought walnut-faced birch ply from HD online with in-store pickup.
I've been continuing with small projects
The glove dispenser is done. The front panel is basically a vertical drawer that pulls out to replace the box of gloves. The bottom backside of the face is cutout for a hidden finger pull. I wanted it to look like a fixed panel so I didn't match the rest of the pulls.
Some of the ply is warping - it's most obvious in the doors, but the bottoms of the upper cabinets are close to eye level. The cabinets along the Northwall at the front of the garage are the worst because it's mostly made of sheets that I rejected earlier. So to fix that I mounted a steel T-bar along the bottom. To hide and help the steel reinforcement, I added a 2" strip of ply. I'm going to add some lighting so the whole thing looks like a valence. I finished painting this section so I could hang a few more bits of garage art.
I'm working on the trim around the big windows now. These are above the big bench and flank a steel post. It's a reasonably large section that I didn't want to go unused so I'm mounting a T-track vertically in the trim. I'll see if there are other uses for it, but I'm thinking of an adjustable height mount for a work lamp. The teaser photo is of groove for the track in the main panel that will cover the post. It will be laminated blue to match the glove dispenser panel that sits on the opposite end of the beam.
