Derusting old sockets
chasewilliams530
How to you go about getting rust off sockets including the inside?
Jimithing616
Minnesota
You could try evapo-rust or vinegar
Sand it down....
I’ve also used magic erasers on light rust on tools
Or a wire wheel, brass wire wheel, then polish it back with buffing compound and a wool or white buffing wheel... if your worried about looks... to get inside the socket, they have wire wheels for Dremel tools that may work.
Other than that, idk, I’m sure someone’s got other ideas....
4xdog
Santa Fe, NM
I'm a big fan of Evapo-Rust. Here's what it did on some old hose clamps from the heater on my 1962 Triumph TR3B:
C
chasewilliams530
I need to find a way to remove rust without removing crome finish will evaporust work for that?
Squ1d
Be careful with impact sockets. I have read that it will also remove the black (oxide?) coating from them.
But I will echo the others recommendations. It does a great job removing rust. Keep it in a warmer location for better and quicker results. I’d put it in a container that seals because it has a smelly odor.
jabberwoki
puyallup wa usa
Soak in gas scrub and clean thoroughly.
Mix a batch of salt and vinegar to the approximate ratio of 1 gal vinegar to 1 cup of salt.
Let them soak for 24 them rinse in warm water.
Chuckem back in if no yet done.
This recipe costs jack **** works like a charm.
No need to spend any more than $2 at your local $1 store.
Done.
C
chasewilliams530
Done.
And it won’t remove the Crome?
4xdog
Santa Fe, NM
Evapo-Rust won't hurt chrome plating as long as the underlying metal is in good shape. If there's rust under the chrome, it'll peel off the chrome as the rust is treated.
As far as I can tell, Evapo-Rust is a weak reducing agent. It adds electrons back to the iron oxide, reducing it back to metal. The Evapo-Rust solution gets blacker as that reduced iron builds up in it and the solution stops working when the reducing agent gets exhausted.
Yes, Squ1d, it would very likely reduce an oxide finish. You bring up a good point there. I wouldn't (and don't) use Evapo-Rust on anything with an oxide finish.
