Design for Rotating Tool Stand on Casters
Jayhawk_Aviator
Im wanting to make a tool stand for my drill press, two bench sanders, and bench grinder. Im envisioning it being squarish, with 1 of the 4 tools at each corner. I'd like to make it out of square tubing and put casters on the bottom so I can roll it out of the way.
Curious if anyone has done something similar and has design ideas to shaare?
Thanks,
Scott
Kaizen
New England
I like the idea of having it movable so long lengths don’t it the walls
Modern Garage
Southern Minnesota
I like this carousel/lazy susan design. What are you using for support of the turntables? There will be some weight there and stability will be needed. I can see something under the corners of the bottom turntable but can't tell if there are bearings there.
Since you say you're working on it now, is this a pic from another project or someone else's plan?
Joe
Motorman55
South Jersey
Looks similar if not the same to this plan...
