Very nice layout.
How close to the property line will this be?
Bill
Thanks!
6 feet away from the property line (fence)
I looked up the specs for a 2016 model. It lists ~80" wide without mirrors. I mocked up 84 inches wide. The truck is nearly 19' long. There is ~6' of space between the side of the truck and the wall, if it's centered between the 10' wide garage door opening. Plenty for the two post lifts I checked out. Here are some measurements with the atlas 9OHSC.
I didnt put anything on that wall because windows and lift depth aren't decided. I figure I'd keep the oxy torch and welding supplies under the stairs and in the bottom of the welding table.
Waste oil is a little cart, I can tuck it where it's useful but out of the way. Ditto floor jack and stands.
Blast cabinet and parts cleaner would definitely be nice to have. I'll see where they'd fit.
I'd mount the bench grinder and vises in different spots to see what works. I read up about the trailer hitch setup. Seems like a really good idea.
Would it be worthwhile to get a free-standing drill press, or are bench-mounted just fine?
Engine hoist and engine stand can be folded and stored in the utility room when not in use.
I modelled a tool cart under the workbench. I assume there will eventually be more tool chests in the future. Right now I just have one and it ain't too impressive.
I added the miter saw, table saw, any other pricy wood tools as future considerations. Consider those shelved in this model. I borrow a miter saw when I need it for now.
I'm looking up whether it would be more worthwhile to get an air-powered atv lift table or a small moveable scissor lift. Scissor lifts can do cars as well as atvs and tractors, but would be bulkier. Some atv lifts can also fold out of the way. It would be in the second bay. It can also double as a work surface when there's no machine on it.
I don't know if I'd ever get a miller or any of the other advanced metal-working tools on that list.I've got a lot of learning (and saving!) to do before I'd even consider them. Maybe an anvil.
