Detached shop power overhead or underground question
bronc076
Ozarks
I lived in Sierra Vista AZ (Cochise county) for 20years, Castro Electric did a lot of the work on post so they probably have some good guys, not sure if they do residential though.
Stuart in MN
Minneapolis
Others have alluded to it, but it's typical that electric utilities will only supply a single service to a residential property, so getting a second meter may not even be an option. It does vary by the utility so you'd have to check.
walta
Dutzow Missouri
Before we throw the electrician under the bus and that was my first reaction. Let’s make a list of the Amp rating for the current 240-volt breakers and what they run and a second list for proposed new loads.
Let’s guess the that the current 200-amp house panel is maxed out and cannot feed the new garage.
If the new 2500 sqf garage needs
30A Heat pump
50 A heat strips
30 A water heater
50 A air compressor
20 A lift
50 A RV outlet
60 A electric car charger maybe 2
Plus, some shop equipment and 120V loads.
Is a 200-amp panel really over the top for the garage?
If you are adding solar in the future now is the time to make room for it in the service.
Walta
tool_scrounge
Southern California
If you go with underground, be there when they trench it and confirm it is at the expected depth. There is nothing like severing internet for the neighborhood because the installer felt like 4” deep was close enough.
Chuckster in NJ
Hunterdon County NJ
30A Heat pump
50 A heat strips
30 A water heater
50 A air compressor
20 A lift
50 A RV outlet
Walta
You have a lot to learn………. NOT even close to calculating loads.
30A Heat pump
50 A heat strips
30 A water heater
50 A air compressor
20 A lift
50 A RV outlet
Walta
that is nowhere near how to do a load calc. youre doing exactly what the OPs electrician did. totally wrong.
txvwnut
Bedford, Texas
I vote underground as that's what I did at my place. If you currently have 200amp service at the house then you could switch to a double lug meter base and then trench from the house to the shop and put in a 200amp panel at the shop and not have to treat it like a sub panel by tying off of the one on the house. Which is what it sounds like to me the electrician is doing. Easiest way to see what amp service you need is to do a proper load calc and then contact your POCO, most of the ones I've dealt with are more than happy to help you with figuring out what service rating you need. Plus with going with the double lug meter base and your current overhead supply lines you won't have to have them agree to an engineered trench for their service just have to meet the needs of the city/county buried service code requirements.
ericm
Southern Oregon
One of the electricians I'm talking to about wiring my to-be-built shop (500' from the pole) suggested that we combine the house and garage meters into one service and have the PoCo install a "ranch meter" somewhere between the pole and the shop. That way we're guaranteed to get full voltage at that meter that's hopefully significantly closer to the shop, and the PoCo will pay for trenching it to the meter. I think. It might help that it's a farm.
It may be worth asking your electrician if it's an option.
PCustoms
VT
This was suggested above, the problem is it may require a new feed to the house.
walta
Dutzow Missouri
The breaker size is not the load.
Agreed the breaker going to at least 20% higher than the load but it is data that one can collect quickly and any data is better than guessing. How much time can one invest in a free estimate.
naw. you add up all the breakers in a panel youll be many times over the rating of the service. again, adding up breakers is completely pointless due to diversity of loads....
as far as the free estimates go, we as a trade need to stop giving out work for free however one can plug in the numbers for a load calc into a pre prgrammed spreadsheet in all of 10mins provided the OP gives the needed details.
and AFAI can tell, the OP didnt ask the electrician if his service was adequate or required an upgrade, which then would require a load calc. instead it seems to me the electrician tried to convince the OP one was needed just to squeeze more money out of the OP simply based on the added load of a vehicle lift... smh :headscrat :wtf::twak:
dccd
Thanks. I have another electrician coming over for bid and now I’m better informed on what to ask and look for and will ask all the questions from your guys recommendation. Appreciate it thanks. W.
Any update on this?
