Dewalt Miter saw question
NUTTSGT
Northern Central Ohio
I'm looking to upgrade to a Dewalt DW779 12" miter saw from my current DW713 10" saw.
I noticed some 12" blades have a 1" arbor while others have a 5/8" arbor. I can't even find the DW779 on Dewalt's site but I can find the DW780. The latter states 5/8" or 1" arbor.
Does anyone own or can you verify what size arbor is on the DW779 or does it include an adapter ?
PureLeaf
According to this website:
https://protoolzone.com/best-miter-saw/best-sliding-compound-miter-saw-dewalt-dws779/
Q – What blade size does this saw use: 5/8 or 1 inch?
A – There’s an adapter available with this saw, which is either for 1 or 5/8-inch blades. Out of the box, the arbor is 5/8.
Off topic but I've used the DW780, love the XPS shadow line. I believe the DW779 is upgradeable to it with a special handle/light kit. I even fitted Dewalt's XPS light onto my bosch miter saw.
N
NUTTSGT
Thanks, I found that link right after I started this thread. While it seems like good info, I hope an actual owner chimes in.
Empty Pockets
Rural New York
Eric- I have a 20 year old CM 12" miter saw. It replaced a 10" saw. The larger blade makes a world of difference. You'll love the bigger saw
MoonRise
Manual available from the DeWalt site.
https://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DWS779&selectedType=27628#
Per the manual, saw has a 5/8" arbor shaft. Use blades with either a 5/8" hole or a 1" hole with the arbor blade adapter (p/n 152636-00 item # 25 on the DeWalt ServiceNet site
https://servicenet.dewalt.com/Parts/Detail/10121
The DWS780 uses the same blade adapter btw. Same 5/8" arbor on the same and use the blade adapter if you have a blade with a 1" arbor hole.
ItsNemo
Canada
Skip the 779 and go for the 780, it's worth every penny to have that XPS guide right out of the box.
rlitman
Long Island
That's a $250 upgrade that I believe I can do without. $349/$599 at Lowes.
Yikes. You can get the parts for about $75.
https://www.mmtoolparts.com/store/miter-saw-upgrade-kit-dewalt
Personally, I don't like any of these guides, laser or shadow. Lasers always have a fuzzy edge, and even the shadow looks like a snake that swallowed a dozen eggs, because of how the teeth stick out from the plate.
I suppose if you're framing it's a time saver, but when I'm using my miter saw, I'm using it for precision cuts where pencil lines are often too thick, so light guides just don't cut it.
One of my favorite features of a sliding miter saw is that I can pull out the saw and pivot it down while it's off, to precisely align the edge of a tooth against my cut mark.
N
NUTTSGT
I had a Cman years ago before it bite the dust. It had a laser on it and I never cared for it nor did I use it. I'm the same, blade down to mark to check before cutting.
rlitman
Long Island
...blade down to mark to check before cutting.
That's part of what I said. Before the days of sliding saws, I had to use a square and draw my mark across the entire piece, because I never new exactly where the tooth would fall when the saw dropped. With a sliding saw, I can pull it out and reach the mark wherever it ends up. The difference is subtle, but significant for me.
N
NUTTSGT
Oh oh, I get that now. Yeah I like that.
cmandp
New Jersey
I have a 779 and it has a 5/8" arbor and came with the arbor bushing for blades with 1" mounting holes.
ItsNemo
Canada
Wait for sale prices...when I got my DWS780 it came with a free stand and was still less than the DWS779.
The shadow system works extremely well and it's much much easier to hit your mark, lasers in comparison are useless.
N
NUTTSGT
I'd like to wait till I sell my 10" saw to help fund the new saw. Although, I don't have to, we just spent $1400 on a new washer/dryer so I'd like to allow the financial funds to build back up before I buy.
I was also considering waiting for Black Friday ads to come out and see if either HD or Lowes have them on sale.
A DW780 for less or the same cost as the DW779 with a free stand, I'd be all over that deal.
:thumbup:
N
NUTTSGT
A little update. I waited for the BFads to come out. I compared HD to Lowe's. The latter will give an extra 10% military discount.
Both DWS779 saws come with a stand. The Lowe's stand is a folding four legged stand. HD free stand offer includes the one that has wheels and folds down like a dolley. No military discount.
So for the extra $40, I'll take the one with wheels from HD. Better yet .....
....the wife is going to buy it for me for Christmas. Sweet.
N
NUTTSGT
Act surprised when you open it up on Xmas. I’m sure the little card will include little tidbits like can you do this, this, and that other project over there.
I actually ordered it last night along with her wine cooler. It'll help with the kitchen remodel.
shawhite
why not go with the 10in slider. I seriously doubt you will run into much it won’t cut with one pass. Not to mention blades are cheaper and saw is a little lighter
rlitman
Long Island
Most 10" saws can't cut 4x lumber in a single pass. Most also can't cut a 2x6 vertically. Every 12" saw I know of can do this.
As for blade price, it's a wash. Blade prices tend to follow blade circumference. Bigger blades cost a little bit more, but also due to a larger circumference, tend to last a little bit longer. My best educated guess is that the price per cut will work to to be the same in the end.
Still, 10" saws are lighter and take up less space in a work truck. If you're a mobile trim guy, then a 12" saw probably doesn't make sense as your primary saw (unless you're on a job that calls for huge crown moldings). For my stationary setup, I'm not bothered by the weight or space loss.
bobsled_time
Greenville, SC
I have the non-sliding version if this saw. It has a 5/8" arbor with a little adapter piece to make it fit all of the universal blades. Though looking now, it looks like they're available in both a 5/8" and a 1" arbor. Seems odd.
shawhite
Most of the newer 10in sliders on the market will cut 4x material in one pass. I guess If you were cutting true 4in material you may have an issue but typical dimensional lumber you will be fine. They also can usually cut 5 1/4 base vertical even though you maybe limited to only cutting on one side. What would be the purpose of cutting a 2x6 vertically? I tend to have several blades for my miter saw depending on what Im doing so blades cost can add up.
rlitman
Long Island
...What would be the purpose of cutting a 2x6 vertically?...
Miter adjustment is just easier and more accurate than bevel adjustment, and I've cut many a 1x6 and 2x6 vertically on a 45 for things like raised flower beds.
I'm not at all saying that 10" saws are incapable of most jobs or that 12" saws are inherently superior or the right choice. Just that I don't have anything against 12" saws.
shawhite
I understand I was just trying to put another option on the table. I can definitely agree it’s a lot quicker to cut vertical.
dsimatt
Shhh, had to help the jolly day man in a red suit today with a delivery.
Congrats, did you take advantage of the black Friday sale, mines sitting in the garage right now waiting assembly.:beer:
