Above 1200 Sq/FT DFB's Garage
D
D.F.B
Australia
And so, look what I found...........................my lawnmower unicorn, a Rover ProCut 560 with the Briggs 850 engine!
I went looking for a viable self-propelled lawn mower back in 2014 to replace the abysmal John Deere JS48. For a contractor, the unquestioned wisdom suggested that I should have been buying a Honda HRU-216. However, after prior bad experiences with Honda's, not to mention the narrow discharge chute of the HRU-216, I had no intentions of blindly following the crowd.
After extensive research, I was led to an unlikely candidate, the Rover ProCut series. These were 20-inch and 22-inch alloy base mowers, both offered with or without self-propel. By 2014, Rover had ditched Briggs and Stratton in favor of the 196cc "Rover" engine, or the 173cc Kohler Courage XT8. I didn't want either engine, but the Kohler got the nod as the lesser of two evils.
I never liked that Kohler engine. From day one, it seemed to consume more oil than a Briggs, not in a smokey way but it always dropped between oil changes. It has always been harder to pull over, there is a feeling of no inertia. It also lacked the stamina of the 190cc Briggs in really thick grass. I will say, I have belted the **** out of this engine for more than 10 years now, I even changed the position of the governor spring to allow a much higher rev ceiling. To be frank, I was not concerned about blowing this engine up, if it did, I'd then fit the "correct" engine.
That Rover has made me a power of income over the last decade, I've basically ran it into the ground. I did try to find replacement for this machine, but no self-propel mower on the market today has a full width discharge chute. Rover's genius was putting the gearbox on top of the deck, not within the rear chute. As such, I've sunk money into maintaining this unit as much as possible. Only recently, I replaced all of the wheels and rear drive pawls.
I mention all this because I had only just missed the chance to buy a ProCut with the Briggs 850 brand new back then. Rover had always used the OHV Briggs engines on these mowers, prior to the 190cc 850-series, they were also using the older Intek 65 engines. I guess Chinese made engines (including the Kohler) increased the profit margin.
So, to find the unicorn ProCut with the Briggs 850 has me extremely excited! And from the photos, it looks to be in great condition. Look, I need another mower like a hole in the head, but I just couldn't let this one go by, I'll be driving to pick it up next week. And as for my old Rover, it may end up being a parts bin.
Tactile
Melbourne, AU
Two years in the making.......................3 months leave started at 5.01pm this afternoon. I was waiting for the car to arrive before going on leave, but after what happened last week, I’ve actually pulled the pin on it. Even if the car doesn’t arrive next week, I’ll have at least unwound and calmed down a little.
The last two weeks have been murder, and in the last week I've been plagued by constant headaches caused by an out of spec spine..............and most likely the stress. I should be elated but I'm so ****** exhausted and my head is still thumping that it's going to take a while to unwind.
That 3 months leave wouldnt of been long service would it?
D
D.F.B
Australia
Dove into my collection of brochures that I have accumulated over the last 25 years and found a bunch on Rover ProCut.
This one is not dated, but it would be circa mid-2000's. I actually forgot they used Honda engines for a while there, in this case the OHC GCV160 and GSV190. The GCV160 only had 4.0hp, the big bore GSV190 produced 5.0hp. The Briggs engines were the 190cc Intek OHV series, which are different to the newer 850-series engines, the intake/exhaust layout mirroring the 190cc flat head engines. They also offered a remote air filter, missing from the later engines.
Again no dates are printed on this brochure, I'd say it would have been very late 2000's/early 2010's as both the old Intek and new 850-series engines are referenced, although I suspect old images were used here and that in fact all were powered by the newer engines. By now, the Honda's were gone, the crappy "Rover" engine taking its place. The beginning of the end..................
This one is from the 2015 Rover catalog. Briggs and Stratton out, Kohler and "Rover" engines in.
A few years after this, Rover came out with a new line of ProCut models, named ProCut 750, 760 or 960. These has a completely different deck with a similar gearbox design and location. They also included a blade clutch to stop the blades spinning while emptying the catcher, like Honda use on the pro models.
https://www.rover.com.au/pub/media/wysiwyg/2020-21-Rover-Catalogue-FINAL_SP_SMALL.pdf
I remember asking about them at the dealer and was told Rover stopped using the old alloy chassis because apparently "the molding was worn out". Bull ****, they just started using a cheaper chassis produced in China. If the deck molds were worn out, why are SuperSwift and Bushranger still using the old Rover decks?
https://supaswift.com.au/products/lawnmowers
https://bushrangerpe.com.au/products/lawn-mowers
Actually, SuperSwift use the old ProCut 50 chassis and powered by the Honda GXV-160. I just wish they made it in self-propel, I'd be walking across broken glass to buy one!
https://supaswift.com.au/products/lawnmowers/supaswift-797hmc-20-push-mower
D
D.F.B
Australia
Leave Project 1 - Unicorn Chasing!
Regular readers will know of my love for the Rover ProCut. And in that, I mean the ProCut's made before MTD discontinued the classic series and replaced them with something cheaper. The original ProCut's were on the marker for 20+ years, the replacement lasted a mere five. Says it all really. The Rover brand was once a force, it's now a shadow of its former self. Shame on you MTD and your cost-conscious control freaks.
In spring 2013, I bought my first self-propelled lawn mower, the American-focused John Deere JS48. The personal pace drive system, killer Briggs & Stratton 875 engine (it ran so hard that it would ignite fuel in the muffler on shut down, always loved the BANG it made), the key start and a wide 22-inch cut made it the perfect mower. Except, it was abysmally terrible at catching and wouldn't cut low enough for my customers' requirements. I cut my losses after less than a year and started researching an alternative.
Now, for a contractor, the unquestioned wisdom suggested that I should have been buying a Honda HRU-216. However, after prior bad experiences with Honda's, not to mention the narrow discharge chute of the HRU-216, I had no intentions of blindly following the crowd to end up with the same lack of catching ability as the John Deere.
After extensive research, I was led to an unlikely candidate, the Rover ProCut series. These were 20-inch and 22-inch alloy base mowers, both offered with or without self-propel. By the time I was in the market, Rover had ditched Briggs and Stratton in favor of the 196cc "Rover" engine, or the 173cc Kohler Courage XT8. I didn't want either engine, but the Kohler got the nod as the lesser of two evils.
I never liked that Kohler engine. From day one, it seemed to consume more oil than a Briggs, and always felt harder to pull over with strange resistance against the rope. Nor did it have the grunt of the 190cc Briggs in really thick grass. I will say, I have belted the **** out of this engine for more than 10 years now, I even changed the position of the governor spring to allow a much higher rev ceiling. And yet, it doesn't smoke, no piston slap or unusual sounds.
I actually keep a tab on each mower I own and how much income they generate. I originally started doing this to find out when the machine had paid for itself and therefore when it started earning me money, however I just kept going beyond that. So, I have a record dating right back to the day I bought this Rover, you'd be shocked at how much income this mower has generated over the last 10 years!
As age started creeping up on it, I've tried three times to replace this Rover. I looked at the new Chinese-made ProCut 960's while Rover still offered them, but the dealer warned me off them due to issues with the blade-clutch system, his advice was to refresh my current Rover's drive system to buy me some more time. After that, I stared looking again and ultimately took a punt on the Bushranger 800 SP with the Honda GXV-160 engine.
To be clear, I did actually like the Bushranger. The build quality is the best I have ever experienced on mower, everything was made to be super heavy duty, thick cast aluminum deck, sold metal wheels with actual rubber tyres, cross-bolted axles, and shaft rather than belt driven gearbox with three speeds. The GXV-160 engine is superbly refined and efficient, and after a governor adjustment, plenty of power too.
But again, the half rear chute limits the catching ability in heavy duty cutting or on damp/wet grass. And all of that heavy duty-ness meant the unit was extremely heavy, making it dicey on soft/saturated ground. It became a lottery, did I risk being inconvenienced by frequent chute blockages by taking the Bushranger for the day, or did I grab the aging Rover just to be safe. And that is not really ideal when spending the better part of $2000 for commercial mower. At the time of writing, I'll be selling off the Bushranger in the near future, I just don't use it.
The next attempt was considerably more successful, the Victa Commercial 21, a machine I'd had my eye on for quite a while. The problem I had committing to this machine was the lack of info out there on these mowers. In that I mean very little online content, both written and video. In the end, I took another punt and have been very impressed with how it's performed since.
I've gone on to provide content on this mower that will hopefully help others make an informed choice. Overall, the Victa C21 is a great mower, plenty of power, well-made and even with the half chute, it's been performing very well.
All along, I had been replacing and repairing the Rover to keep it in action as a backup or when I knew I'd need that full discharge chute. So, I didn't need another mower, the Victa C21 was a more than capable replacement for my beloved Rover ProCut, but.......................................
A few weeks ago, I found a very tidy looking Rover ProCut on Facebook Marketplace. At the time, I was super busy and didn't want to burn a few hours traveling to buy it when I didn't really need it. So, I told myself that if it was still available when I went on leave, that I would do something about it. The advertisement pics showed a tidy mower that clearly had been looked after.
So, why THIS example? Because this particular ProCut is fitted with the brilliant Briggs & Stratton 850-Series engine! As mentioned, I missed the boat on this engine back then, at the time neither the Kohler or "Rover"
engines interested me, so I went for the "name" branded Kohler. But I really wanted the Briggs.
So, after I contacted the seller on Saturday and organized a time to pick it up, I got in the Ranger this morning and set off towards Cobram-Barooga. This is the first time I have driven out of town on my own mission for nearly 12-months, the first time in 7 years leaving Victoria. I didn't even mind being stuck behind two trucks for most of the way, the road is super bad and not conducive to overtaking in an underpowered 2.2 diesel Ranger, so I just pottered along listening to the divine Miss K. 😎
Once I arrived, I spotted the mower in question was stunned at its condition, the photos didn't do it justice! Chatting with the seller, he seemed to be into mowers as well and once bought (another, not this one) brand-new Rover from the factory back in the day. This particular ProCut was handed down from his grandfather, which nearly had me in tears because I too have my grandfather's old mower. Apparently, the seller was downsizing so the Rover was just too big and heavy for him. The machine was originally sold by Sugden Kerr in Toowoomba, its better traveled than me! :rolleyes:
Lawn Mowers & More at Sugden Kerr Pty. Ltd. | Toowoomba (sugdenkerrmowersandchainsaws.com.au)
After collection and on my way home, for the first time ever, I decided to check out some silo art....................
Once I got home, I mowed the front nature strip to get a feel for it. I then grabbed the tachometer, the 3030 rpm is the fastest standard Briggs 850 I have come across, most of them sit at 2800 - 2900 rpm from the factory. I then grabbed my excellent Knipex curved pliers to bend the governor spring tab towards the front of the engine, bringing it up to a healthy sounding 3670 rpm. This also speeds up the self-propel to a more efficient walking pace.
The seller mentioned it had synthetic oil in the engine, and it still looked golden, if a little over-full. After tuning the governor, the oil was up to temp, so I just decided to change it out for peace of mind. Oil of choice being my usual preference, Penrite 10W-30 semi-synthetic.
While the oil was draining, I took the chance to inspect the blades, which are the OEM style with the three holes. The belt also looks in great condition.
The drive system is a little clunky, which will need further investigation. I did pop off the hub caps and inspection plug to look at the cogs, which looked fine. So, I lubed the cogs with graphite to see how it goes, but if needed, I have a replacement set of cogs and pawls. I then removed the gearbox/clutch cover, blew out a small amount of debris and lubed the drive chain.
For those wondering where the detailing content was, this is where I decided to give the unit a clean. After a rinse with the pressure washer, I sprayed it down with Shine Supply Wise Guy, agitated with a brush and then rinsed. I then followed with Carpro Hydr02 and dried it off with the EGO. After that, I went over the catcher, engine plastics and wheels with Megs Hyper Dressing.
Next, I decided to pull the plug, which was ok but well worth replacement. The 850-Series uses a Champion RC12YC or NGK BCPR5ES, of which I keep the Champions in stock. You will need a 16mm deep socket for this.
Annoyingly, I didn't have a brand-new air filter in stock. These earlier 850 engines used a longer rectangular filter instead of the triangular version on the newer engines. A clean used filter I already had will have to do for now, which was better than what came off the machine.
After a basic service and a clean, the Rover is ready for work. Hard to believe this is a 10-year-old mower........................
Comparing my well used Kohler powered example, the main difference being the bale/drive lever. The Briggs version has a single drive bale, but the Kohler uses that for the engine brake, as such it has a secondary lever to control the drive. I've always hated the useless engine brake and used a small clamp to keep the engine running to prevent restarting after each catcher dump. But I did like the single-handed drive control lever better, so no doubt some adjustment on my part will be needed.
On final thing for today, I removed the zone-start clamp from the Kohler powered machine and fitted it to the Briggs.
As for further work, I will most likely pull the wheels off and replace the drive pawls, the cogs looked fine. I'll also order a new air filter, as well as an exhaust tip.
So, I found my unicorn lawn mower! I just have to find a decent Victa Twin and my life will be complete!
And joy of joys, I managed to get the Ranger dirty enough for a wash!
Thanks for reading my babble. ;)
D
D.F.B
Australia
After debating what to use on my S650, I concluded that I would just use a traditional wax or sealant to protect the paint. But at the 11th hour, I changed my mind and went with a ceramic coating that has been getting a lot of positive review. Armour Detail Supply Quartz, in particular the non-pro version.
Unlike a lot of coatings, ADS Quartz doesn't require additional topcoats to achieve slickness, Carpro CQuartz UK 3.0 topped with Gliss or Gtechniq CSL topped with EXO for instance. I just need the car to apply it to now..........................:rolleyes:
D
D.F.B
Australia
Leave Project 2 - Sell, Sell, Sell!
As mentioned in the previous post, the Bushranger and Stihl HS 45 are on the chopping block and will be put up for sale. Both have seen little to no use and have been taking up room in the back of my garden shed. These machines owe me nothing, both having paid for themselves long ago.
First up, the Bushranger. I bought this mower in September 2020, but it has sat idle since I bought the Victa Commercial 21 back in February this year. The first job here was to make sure it was running, so I drained the fuel out of the tank and carburetor bowl, then put fresh fuel in the tank and gave the cord a yank, it started on the second pull. Nice.
Next, I replaced the air filter with a brand new one, then an inspection of the blades. I didn't anticipate needing to replace the blades, but they were too dicey to put up for sale, so I dropped the disk and replaced them with some I had in stock. I won't be needing Honda air filters or this blade set in the future, so I may as well send them off with the machine, I'll factor this into the asking price anyway. The oil was still golden, so I left it be.
So, running and with some new parts, it was time for a clean. Like yesterday, I used Wise Guy, followed by a coat of Hydr02 and Hyper Dressing for the plastics.
Ready for sale...................
I'll miss that engine, everything about it screamed quality, in a way that the similar looking Kohler could never hope to achieve. It was responsive, easy to work on, smooth running, the low idle tick-over delightful, and backed up by fuel efficiency the big-block Briggs could only dream of. Everything about this mower was heavy duty, it felt un-killable. But............its time to move it on.
Next, the Stihl HS 45 Hedge Trimmer............................
As you can see, this thing was looking very sad! This machine was sidelined in November 2018 after getting a battery powered HSA 56. Originally, I decided to keep the petrol powered HS 45 as a backup as I wasn't completely sold on battery power at that stage. I remember the first hedge-job (I know, that sounds rude) I took the battery powered HSA 56 on, I actually took the petrol unit with me just in case I ran out of battery. Well, the petrol HS 45 sat in the truck all day................and was NEVER used again. So, it really should have left my company long ago.
Having sat for the better part of 6 years, I fully expected to be doing some sort of carburetor work on this machine. But first, I needed it clean to work on. Again, Wise Guy, Hydr02 and Hyper Dressing to the rescue..............
Now clean, I opened the fuel tank to see what I was dealing with. I committed the cardinal 2-stroke sin with this machine in that I stored it with fuel in the tank, fuel lines and carburetor. The fuel had actually evaporated long ago and left a slimy oil reside in the bottom of the tank. To remedy this, I splashed some fuel into the tank, shook it up and then dumped it into the waste oil drum.
Next, I splashed some fresh 2-stroke in the tank and pushed the primer, as expected, it crumbled under the pressure of my finger. So, on with the choke and several pulls of the rope until it finally gave a slight splutter, I knew then it would run. A few more pulls and I had it idling but bogging under throttle. I've done this enough now to know it would eventually clear as it burnt off old fuel, I could smell it too. After about a minute of working the throttle with gentle blips, the thing cleared its throat and was running HARD. To have sat for so long with absolutely no preparation beforehand, I couldn't believe it! I have a suspicion that after the fuel evaporated, the 2-stroke oil it left behind kept the diaphragms in the carb pliable.
So, I was expecting to have to pull the carb and replace all the fuel lines, but all I'm up for is a purge bulb, which is a simple replacement. The local Stihl dealer stocks them, so I'll run down and grab one tomorrow and it too will be ready for sale.
Giving the engine a good workout, including several restarts to make sure it was running and starting properly, I was reminded why I stopped using this machine. First, its ******** noisy, especially when you end up having the engine so close to your ears when working. You also end up with the exhaust blowing smoke all over your body, so at the end of the day you stink like a 2-stroke engine. I would also say a battery machine is safer as there is no wind down of the blades, they stop when the motor stops. And its heavy compared to a battery powered machine, which in turn puts strain on your shoulders and upper body. Lastly, there is no anti-vibration on this model, so you end up with pins and needles after extended use.
And so, this is one area where I'm 100% committed to battery power, and therefore not sorry to see this machine depart.
D
D.F.B
Australia
After yesterday's mini road trip, the Ranger needed a wash!
Trust me, it looked worse in person, the windscreen in particular. After washing the wheels with foamed Brake Buster, I soaked down the whole vehicle with Gyeon Foam and allowed it to dwell. The rinse that followed removed the bugs easily, ceramic coating for the win here. It was then time for the contact wash.....................
Soap of choice today was Meguiar's NXT Car Wash, a product that I used extensively for many years, mainly on my FG XR6. Thinking back, I remember NXT being a champion of suds, so I wondered how it would foam.........................Very well as it turned out. Actually, more than well!
First of all, the grape scent of NXT took me back to my early 20's, much the same as the ArmorAll stuff did a few weeks ago. Mixed into the foam cannon, NXT produces medium to thick foam and felt very nice under the wash pad. At this point I was impressed, but it wasn't until I started to rinse the soap off the car did it finally click, this is Meguiar's BEST SOAP! Up until the rinse, I was thinking NXT was very similar to Hyper Wash, if not quite as foamy. But the way it instantly rinsed from the vehicle set it apart, Hyper Wash in comparison requires significantly more effort to fully rinse off the car.
The only drawback to NXT is the ultra-thick consistency, the key reason I chose to move away from it. However, now that we have wide-mouth foam cannons, this aspect is less relevant as you don't have to dribble a thick soap into a narrow foam cannon bottle. But still, I think this is a killer soap!
For the rest of the detail, I used OG Drying Aid on the paint, Gyeon Quick Detailer on the door jambs and tray, glass attended to with KCx Speed Glass, interior wiped over with ADS Pilot. To finish, the wheels got a quick wipe with ADS Amplify, tires dressed with ADS Tire+.
littlebean
I think you're the only person I've heard of who details their tools :)
D
D.F.B
Australia
Despite my neck giving me gyp again, and dealing with nuff nuff's on Facebook Marketplace, nothing is going to take me down today!
First, probably the easiest repair I have ever done, replacement of the HS 45's primer bulb.
This is as simple as it gets, four small Phillips head screws, prize the plate away from the carb, push out the old perished primer cap, then push in the new one. Put the plate back in place and reinstall the screws and the job is done. A working primer the result!
Next, it was off with the new Rover's rear wheels to sort out why it wouldn't "free wheel". As mentioned the other day, the cogs looked ok through the inspection port, but I decided to replace the cog and pawls as I had them in stock. Removal of the wheels was difficult, those tension washers are a ******* to remove, then there were burs on the wheel shaft which I needed to file down to remove the wheel.
On the first side, nothing looked out of spec, in fact the cogs looked perfectly serviceable, still, I replaced them and lubricated the outlet of the driveshaft as it was squeaking. With that wheel put back together, I moved to the other side and immediately discovered the problem.................
In this case, the pawl (the thin piece of metal that slots into the driveshaft) was frozen in place, which prevented it from moving out of the way to allow free movement without the drive engaged. After cleaning the shaft, which also required some abrasion in the slot of the driveshaft to remove some rust build up, everything went back together for a test run. Success! She is driving smoothly and will free wheel and not lock-up when making turns. Again, I can't believe I have a basically new Rover ProCut!
D
D.F.B
Australia
Next on the agenda, the Ranger's headlights were bugging me!
I've covered these dam things many times now, the horizontally exposed surfaces succumbing to UV damage from very early in the car's life. Replacement requires the removal of the bumper, which I can't be bothered doing. The same thing is happening to my father's newer PX III Wildtrak. I've been polishing them out every now and then, followed by a sealant, last time I put Gyeon Pure EVO on them. I even tried my hand at putting PPF on one of them before cracking the sh.ts in frustration................I don't have the patience for that sort of thing.
So, here we are again polishing them out, Rupes DA Coarse on a microfiber pad, followed by Rupes DA Fine on a yellow foam pad. Note, they looked worse in person, the camera hides the haze.
This time, I lashed out on a headlight specific coating to see if this will give me better results. Optimum Opti-Lens Coating is an advanced polymer coating that was designed specifically for headlight lenses..................
"This hybrid resin is a combination of Opti-Coat 2.0 ceramic resin and an acrylic resin for maximum bonding and protection of acrylic and polycarbonate lenses.
Additionally, Optimum Opti-Lens Coating contains high levels of UV absorbers to minimize discolouration and fading of automotive headlight lenses."
https://detailingshed.com.au/produc...opti+lens&_ss=e&_v=1.0&variant=41465942278303
That small 10ml syringe of product is supposed to coat 5 - 6 sets of headlights, so like any coating, a little goes a long way. Once the headlight is polished and wiped down with IPA, the coating is applied and allowed to sit for about 5 min, any remaining high spots are then leveled with a towel.
I have no idea if this will give me a longer lasting result, Optimum suggest the bond is permanent and can only be removed with abrasion. I've seen claims of up to 12 months or more. We shall see. In the meantime, I'll also apply it to the old mans Wildtrak and see how it goes. Otherwise, I'll bite the bullet and pull the bumper off and replace them.
D
D.F.B
Australia
So, my day actually started with me feeling sore and sorry for myself, I didn't sleep very well, and my neck is giving me grief again. After breakfast and a strong coffee, I got in the car for a trip to the bank, the Stihl dealer and then off to the Ford dealer to leave my number plates and touch base again, in that order.
In actual fact, I had only ever spoken in person with my salesman twice, first was on the 21st of September 2022 when I put down a deposit for a new Mustang. I then sat with him on the 30th of October 2023 when Ford released pricing for the new Mustang. All other correspondence has been by phone, text message or email, which suits me just fine.
Standing in the bank to be served was an exercise in frustration, always is. On my way out of the bank and the Stihl dealer next on the agenda, I took a glance at my phone and spotted something that took my breath away!
D
D.F.B
Australia
That picture was taken seconds after delivery. If I had gone to the dealer first instead of the bank, I would have seen the car being driven off the truck! Safe to say, I didn't go to the Stihl dealer next! I messaged back and said I would be arriving in a few minutes!
As I walked into the showroom, I spotted the car sitting in the delivery bay, the salesman collecting all of the build sheets and window sticker. As he walked towards me, I started to choke up and was nearly brought to tears................................after 765 days, or 2 years and 25 days, my new car landed at my local Ford dealer!
The car is dirty, as expected, but oh so sweet in person. As others have noted, pictures don't do the S650 justice. Compared to the S550, this new Mustang is sharper and tauter looking. Those blacked out headlights are soooo good, especially comparing to the non-black pack Mustang that was also delivered today. I still hate the wheels, they block the view to the red Brembo calipers that come standard with Magneride.
I also got the opportunity to fire up the engine for the first time, and a few cheeky blips of the throttle with the exhaust in track mode. Compared to my S550, its a little tame, so I may end up swapping out the suitcase resonator for an X-Pipe, I actually love the standard angled exhaust tips.
After an extended chat and walk around the car, I also got to meet the detailer in person to go over what I wanted and to show him over the Flow number plate brackets. They will wash the car as normal, I want it presentable and any issues noticed/sorted before delivery. I know a lot of guys say "DONT TOUCH IT", but I would rather anything wrong noticed before I hand over the cheque. There will be no polishing either, which he understood after I explained my background. I feel like I'm in safe hands.
Being mid-week and the detailer away on Friday, I was happy to have the car delivered next Tuesday, I want it done right. There is probably more to say but I'm so wired at the moment!
I can't believe it, its actually happening!
D
D.F.B
Australia
As mentioned, the salesman grabbed the window sticker and production line papers before they went in the bin. I mean, they are meaningless to most and only the very die-hard car guys would get a kick out of this, but its nice to have. I'll be making copies of the S550 versions and will send the originals with the car for the new owner.
D
D.F.B
Australia
One down, one to go.
I managed to sell the HS 45 within 24-hours, it went to the guy who didn't even ask for a discount, in other words a gentleman. I of course knew what I would be in for, but it always surprises me how stupid some people can be.
"Is this still available"............................well, yes it is, I only listed it for sale 60-seconds ago. :rolleyes:
Or this little dance...................
Hello, is this still available?
Sure is................
$110 and its done!......................
$100 I'll pick it up now mate
Deal! It does need a new primer bulb, which I had intended replacing tomorrow anyway once I get the part, but it still runs with or without.
How much is the primer bulb?
About $5.00.
And that's where the conversation ended. First of all, I don't know you, you are not my "mate". Why does everyone talk like that when selling something. Mate this, mate that. No! We are not mates. Secondly, if the difference between buying something or not comes down to $5.00................well, you shouldn't be buying used **** off Facebook if you can't afford a $5.00 primer bulb!
Then, someone wanted to swap my hedge trimmer for something else. I'm trying to get RID of some ****, not acquire more!
Anyway, I'd say all this was amusing if it weren't so silly. And THIS is why I'm trading my Mustang and not playing the idiot game, albeit at considerably higher prices.
D
D.F.B
Australia
Also, I only just realized something went wrong with my image edits, I had two years to get that post right! :confused:
cccoltsicehockey
Charlotte, NC
More big-box store soap testing with two additional contenders arriving yesterday. The irony here being that I had to order these two as the local Repco doesn't stock them.
The purple NXT is a soap from my past, used on my XR6 for many years. The pink Soft Wash Gel I have only had a brief encounter with, from memory my sister was using for short while. Meguiar's offer a huge range of soaps with far too much product overlap. It also appears that certain soaps are region specific, NXT and Soft Wash Gel don't appear to be sold in the USA for example.
Soft Wash Gel is Meguiar's entry level soap in Australia and is often on sale. Strangely, Repco have it at $21.00 for 473ml, yet Meguiar's (terrible) official website has it listed at $19.99 RRP. And if you Google search it, you will find a range of prices including $11.99, $13.95 and $15.99. In other words, don't pay full retail on it.
The first thing you notice is the strong cherry scent and the ultra-thick gel-like consistency. That thick consistency is common to every Meguiar's soap I have ever used, but then, their soaps have been left unchanged for decades. Soft Wash Gel is pH neutral and contains "conditioners with optical brighteners to enhance the brilliance and gloss of your paint finish."
I'm fairly sure Meguiar's never intended for Soft Wash Gel to be used in a foam cannon, but that didn't stop me from seeing how it performed. The gloopy consistency does make it harder to mix in the foam cannon cannister, but then it's not alone in that regard, Adam's blue soap is the same.
Foam quality is not its strong suit, not that I'm surprised by that. While the foam is on the thin side, its considerably better than the Autoglym junk I tried last week. However, Soft Wash Gel is an excellent bucket soap, it produces plenty of suds that hold on throughout the wash. Under the wash mitt, its nowhere near as slick as my current benchmark, Carpro Reset. Cleaning ability is fair (yes, the Ranger was dirty this week, I promise), the rinse off easy enough.
Like the ArmorAll soap from last week, Soft Wash Gel serves a purpose but is not for the detailing enthusiast. For the price, I would actually give the ArmorAll the win as its way better value for money being more than half the price for a larger 1000ml bottle.
For me, the biggest problem with Soft Wash Gel is that a 500ml bottle of Carpro Reset is only $5.00 more expensive when comparing RRP's. Reset is easier to pour, is considerably slicker, produces lovely thick foam, and is more concentrated so the extra $5.00 cancels itself out.
Up next, I'll be reacquainting myself with NXT and Gold Class.
The past week has been terrible, situations I never, ever want to experience again. You know, I think we all know about our own foibles and character quirks, but it's never pleasant to have them aggressively thrown in your face in front of your peers. I strongly believe a person's natural character traits are virtually impossible to change, they can be suppressed but there is always a default mode. It's foolish to expect or demand that someone changes their natural traits for someone else's benefit, it becomes exhausting for all involved trying to swim against the tide. I have some decisions to make during the next three months.
Damn the NXT name. Now there is definitely a blast from the past of my first couple years of getting into cars.
Sorry to hear about your struggles at work. That is never fun thing to have to deal with. Hopefully, everyone involved can take a step back and things can work out. You seem to really enjoy what you do there.
Well I didn't read far enough before posting so glad to see you took your leave early and get away from the stress of it all for a while.
Geoff289
Melbourne, Australia
About $5.00.
We're going through this sort of **** getting rid of stuff from my Mum's place. It's infuriating. I know that FB has that "Is it available" button just to generate traffic but it mystifies me why people without any real interest in what you're offering can't resist clicking it. Then there are the ones that don't read the ad properly, want you to deliver a $50 item to the other side of town even though the ad says clearly pick up only, or turn up in a vehicle completely inadequate for the job at hand.
The best (or worst) one involved the sale of a hospital grade electrically adjustable double bed. I emphasised in the ad that this thing was prodigiously heavy and it was really a four man job to load it - I know this from taking it in to the aged care place Mum was in and then getting it out when she passed. In the exchanges we had to do the deal and agree a time I noted its weight again.
So she turns up by herself. Not only that but for reasons best known to herself drove up onto the wide nature strip and got bogged. I again pointed out how heavy this was. "You can help can't you?" I was so close to telling her to go away, but as she was the only interested party in the bed after a few weeks on the market and I had the price down to about a tenth of its cost only two years from new, I bit my tongue. I rounded up some strong teenage neighbours of Mum's, one of whom snatched her out and we got it loaded. Then I spent a few hours trying to repair the nature strip.
The close second would be the couple who turned up to get a three piece modular corner couch thing in an X Trail, and a pretty old one rather than a larger newer one at that. When I enquired as to the plan my attention was drawn to it also having a roof rack. F@#K ME! They ended up doing it in three 50 k round trips. I waited for them to come back for the second load but couldn't stay any longer so we then had a small blue about leaving the last piece in the driveway. I had the money in my pocket at this stage. It was threatening rain so I found an old and not too clean tarp but that was it was far as I was concerned. It was gone the next time I was there.
Tactile
Melbourne, AU
I refuse to use Facebook or Gumtree...Ebay is bad enough. I will give to the poor or relatives (same thing I guess) before I stuff around with the clowns on these sites. Car or Bikesales is the only medium I use for vehicles.
Why dont you get your neck looked at DFB? Plenty of good Chiropractors in Shep.
D
D.F.B
Australia
I have an excellent Chiropractor, the best I have ever experienced. I went there last Friday, it came good but has returned. It was so bad last time that he asked for me to come back in a week, so hopefully it will be sorted tomorrow for the "big day".
D
D.F.B
Australia
Yeah, NXT was like THE thing back in the 2000's. ;)
I'm happiest at work when immersed in the plant side of the business, or creating ways to display stock to be appealing to customers. But its the "people" side I have always struggled with.
Customers, well I'm considerably better than when I started, but I'm not naturally a bright and bubbly sort, I'm very introverted. That is probably not ideal in a retail location, but I've worked hard on that over time, helped as I gained confidence in what I was selling. When you have a regular customer who you know by name come in, or maybe someone who is receptive to advise and genuinely appreciates your assistance, well that is highly rewarding to be part of.
But..................some customers are so ****** entitled, the concept of "the customer is always right" goes too far sometimes. Just because you are the customer, that doesn't entitle you to be rude, cheeky, grumpy, make personal insults, demand a discount because you bought three plants last decade, stop me mid-sentence to answer your phone, interrupt me while speaking with another customer, extort a discount or refund..............................all and more a frequent occurrence. And if you don't **** it up and pander to such behavior, well, you just gave that person "bad customer service". And with how connected the world is, those people go and post their experience online, conveniently leaving out their contribution to the outcome.
Then there is the staffing side of the "people" equation. We all have our faults, but we all have our positives. There is stuff I am brilliant at that others can't hope to match. On the flip side, there is plenty I struggle with. A smart business will learn to manage that, allowing staff to lean into their positives......................not crucify the staff member for struggling in other areas. It's also important to highlight both good and bad, build people up rather than taking them down. I realize not everything can be rosy, but constant negativity just smothers moral and leads to a "why bother" mentality.
Nothing in life is perfect, no doubt about it. Hence me waiting two years for Ford to sell me a car. I guess what matters is how we react to the bad stuff, and then the flow on effect. I'll stop there.
littlebean
crikey, sounds **** - mind you at least you're not trying to herd cats (students)..............
D
D.F.B
Australia
Over the last two days, I've been clearing out the **** that had accumulated in a storage shed that I rent with my old man. Other than the car (the XR6 at the moment, its coming home next week!) and some old car parts, most of the stuff in there is his, which is a little jarring since I pay for it. In fairness, a lot of that was retrieved from his holiday cabin that flooded in late 2022. Insurance covered the rebuild, so that stuff was never going to be re-used, so OUT IT WENT! I took three large Ute loads to the tip. Some of the furniture is still to be redeployed, and I want to pitch those old fridges too.
Trust me when I say that the above shot is what I consider tidy compared to what it looked like yesterday morning. Put it this way, I can actually walk in there now. Funny how you tolerate things when time isn't on your side.
I also FINALLY sent the exhaust off my S550 to the recyclers. Note the black rustproofing paint they spray everywhere on export Mustang's. Fairly sure they still do that. :confused:
There is a guy who lives around the corner that likes to stop and chat while on his walk, usually when I'm detailing or working on something in the garage. Well, he told me yesterday that I need to go back to work for a rest! :rolleyes: If only he knew the whole story, trust me, this is NOT work!
D
D.F.B
Australia
On boxing day 2021, I installed Swisstrax in my garage. Prior to this, I absolutely hated how the floor was ALWAYS dirty, often within minutes of cleaning it. And because of my detailing focus, I was frequently standing in puddles of water as I worked. And peeling paint never looks good. :doh
I looked at several flooring options, but for me, Swisstrax rose to the top of the list the more and more I learnt about it. The key factor that won me over was that I could simply cover everything up with minimal prep work or having to completely evacuate my garage for several days. Also, installing it myself meant keeping control of the job.
There are now several similar floor tiles on the market, but Swisstrax is the original and best. The tiles themselves are thicker, which reduces that click-clack noise under foot. Dealing with Flexico was brilliant, they knew what this meant to me and had a design layout and exact number of tiles required sent to me in no time.
The install took me about 6-7 hours. While the bulk of the floor went down quickly, a lot of time was spent moving stuff out of the way and making the cuts. I had some help with the moving, and in setting down tiles ahead of me as I worked on my knees clicking each in place. As for the cutting, yeah, I screwed up a few, but then I had ordered extra tiles just in case. To save time on the day, I unpacked the boxes and boxes of tiles into the tray of the Ranger, this helped speed things up.
Instead of completely gutting the garage, we simply moved larger items onto the already completed sections to gain access, then slid them back into place.
As mentioned, the cuts took a long time to complete. Each tile needed to be measured, marked, taken out to the saw, cut, then returned and fitted. Over and over again.
The transformation ended up being multifaceted. First, it solved several practical issues in one step. Secondly, it transformed how I felt about the space, it going from a workable situation to something I became proud of. Thirdly, despite my legs and knees taking a week to recover, the actual install was very enjoyable! I think that I had watched so many install videos prior to my own that the actual process was very orderly. Seeing the floor go down tile by tile, row by row, well it was almost surreal that this was actually my garage.
The single most common question I get when asked about Swisstrax is "what happens with all the dirt". Which is a valid question, because it has to go somewhere, and was something which made me initially dismiss Swisstrax. And the answer to that is, well it falls through the gaps and sits on the floor underneath.
There is a few reasons why this is the beauty of Swisstrax, and Swisstrax Ribtrax in particular. Firstly, the curved slats in the tile helps trap debris that blows in within the first few rows rather than blowing from one end to the other. Any dirt, dust or liquid will then pass through the gaps in the tile, in turn keeping your standing surface clean and dry. And because each tile is 18mm deep, it keeps that dirt/dust/liquid suppressed.
In terms of cleaning, those slots that allow debris to filter through also means you can remove it too by simply vacuuming the floor like any other surface. I've also used my pressure washer to blast them clean on occasion, the channels molded into the underside of each tile allows water to drain away.
So, after having had the floor down for nearly 3-years now, I decided it would be a good time to go a little deeper. For the most part, it's the door end of my two-car deep garage that collects most of the debris and occasionally has cars washed on it. With that in mind, I didn't bother with the far end.
The great thing about Swisstrax is that you can remove large sections of tiles in one go. So, I divided the area into four sections, which I tore up and dragged into the driveway. Then, I foamed the tiles with Bilt Hamber Touch-less, allowed to dwell, then rinsed clean.
While the tiles soaked, I vacuumed and then rinsed down the concrete with the pressure washer. What lay beneath the tiles wasn't too bad, but still worth doing.
The hardest part of the job was re-installing, lining up and then snapping each section back into place took some patience. Still, it was surprising how much grime the Touch-less removed from the top surface of the tiles, almost like brand new again.
D
D.F.B
Australia
After the cleaning session, I brought the Jaguar back in for a rinse-less wash. Today, I wanted to indulge in the addictive mango scent of Opti-Coat No-Rinse......................
Optimum Opti-Coat No Rinse Wash (473ml) - Detailing Shed
Opti-Coat - No Rinse | The Rag Company
Compared to the blue ONR, the yellow version has Si02 in it for superior gloss and slickness. With the influx of new "ceramic" rinse-less wash products over the last 12-months, it's easy to forget Optimum/Opti-coat already had a player in this space. Yes, it's expensive, but it's also really nice to work with.
Following the wash, I towel dried with ADS Amplify as the drying aid. Considering the Si02 already in play via the ONR, you could probably skip drying aid, but why deprive myself the chance to use the delightful Amplify.
Next, I dried the door jambs using ECH20, wiped the glass over with KCx Speed Glass and vacuumed the drivers side floor mat. Apart from a pressure rinse, the wheels and tyres were not cleaned but I did give the tyres a swipe with some Carpro Perl at 1:1.
It was then time to make my way back to the storage shed, the Jaguar swapping place with the XR6. After getting the Jag all tucked in and locked up, I gave the Falcon a little run, stopping for some fresh 98-ron premium on the way home.
My Blue Rocket home at last, its battery hooked up for some nourishment.
Believe me when I say that I have been waiting for this moment for a while. I now have all of my Ford's under the one roof, ready to meet their new stablemate next week. 😎
D
D.F.B
Australia
It's been a very slow start to spring this year. By now, I would normally be well into a fortnightly routine keeping grass under control. But the grass just isn't growing, a few warm days is then followed by a few cold days. Up, down, up, down.............................I mention this because I had five lawns (same payer) booked for today but were delayed until next week. So, I had got an unexpected day off. (And yes, I'm still doing my private work, its hard to step away when its your own business at this time of the year.)
So, I went and got a fresh haircut, got to look good for my lady in red tomorrow, then a casual drive of the Blue Rocket. I then got home in time for a buyer to come and pick up the Bushranger. That means I'm back down to only 11 mowers. :rolleyes: It went to someone about my age with a large lawn to maintain, apart from a lowball opening offer, the guy was a gentleman and paid what I was asking, he therefore got an extra air filter, the mulch plug, the owner manuals.......................and a dam clean high end lawn mower!
Next on the chopping block, the Husqvarna 525BX blower. I originally bought this unit after a string of Stihl BG55 and BG86's dating back to the early 2000's. Initially, I liked it, but it became very temperamental on really hot days and overall, I preferred the Stihl. In the end, I went and bought another BG86. I've been using the Husqvarna around home, but it's unnecessarily taking up space.
I was also going to sell off a Stihl FS45 trimmer that had been sitting down back for many years. I cleaned it down, added some fuel to the tank and managed to get it started with some starting fluid down the carby. It then bogged out and refused to start again, no matter what I tired. I was all set to go and order a new carb or carb rebuild kit, then I noticed the shaft was bowed, something must have landed on it at some point. I then decided it was not worth me selling, even if I got the engine running, it would have vibrated itself to death. While it hurt to do so, it ended up going to the tip.
Next up today, the Wildtrak was well overdue for a detail. Mixing things up today, I decided to do the interior first. For the leather, I thought I would have another crack at the newish Carpro Cleanse and Lotion duo.
I still don't love these products, the ColourLock cleaners are far superior, as is ColourLock Leather Protector. I think I prefer the foaming action of the ColourLock cleaners, and Lotion goes on too oily, even if it dries smooth. I also don't like the scents. But, if you never try, you will never know.
Actually, I could not locate the links to the Cleanse and Lotion kit, only the 500ml bottle of Cleanse. Neither Cleanse nor Lotion are represented under the specific leather care section, the kit missing in action. So, maybe Waxit don't like them either? For US readers, these are the links, not that I recommend them...................................
CARPRO SkinCare Leather Kit
CARPRO Cleanse Leather Cleaner 500ml (17oz) *New* - Skys The Limit Car Care
After finishing the interior, it was then onto the exterior. Tires were hit with Wise Guy, the wheels with foamed Brake Buster. I then used up the remainder of my supply of Bilt Hamber Touch-less, then onto the final contender of my auto-store soaps.....................
Like NXT from last week, I used Gold Class for quite a while. At the time, I wasn't always foaming, but when I did, measuring out the gloopy Gold Class was difficult. Also like NXT, that is not really an issue now with wide-mouth foam cannon bottles. Foam quality from Gold Class is medium to thick and with good holding power........................
The best thing about Gold Class is how sudsy it is, and those suds hang around right up until you start rinsing. I really like how it stays active and doesn't run off the panel after cleaning a section, in turn helping prevent it drying too quickly as you work around the vehicle. (Yes, I wash in the sun, but I pick my mark and work quickly). The flipside to that is it requires longer to rinse clear, a contrast to NXT which is extremely free rinsing.
One other point on Gold Class, many have noted it can leave a residue behind and cause a streaky/hazy appearance. From what I can tell, this is from the conditioning agents and gloss enhancers not playing well with certain ceramic coatings. That was not an issue on the Wildtrak, which is in need of a fresh coating in the near future.
Finishing off the car, I used Meguiar's HCD as the drying aid, Invisible Glass for the windows, tyres dressed with Duragloss 253.
While I was detailing the Wildtrak, I got a call from my salesman confirming the details for tomorrow. He then went on to say that I had already seen the car just after it got off the truck.................at which point I was getting very nervous about what would come next and perhaps something was wrong.................only to be asked if I still wanted the reveal cover and bow.
Apparently, he once had customer call him every name under the sun for covering up the guy's new car, and that he now asks every customer the same question. Geez, some people are hard to please. It's a ****** satin sheet, it's not going to ruin anything, and I can almost guarantee that car has had far worse things done to the paint since the guy took delivery! So, yeah, my car will have a satin sheet and big bow on it to mark the occasion, why ****** not after spending the better part of $100k on a car!
Xti04
Question for you, are your " professional push mowers " the go to for guys doing lawn care in your area or are large walk behind or zero turn not a thing down under? I have push mowed many a yard but once I purchased a larger mower I had no regrets and cut my time spent way down. With a set of ramps and your truck you could drive it up to the bed instead of having to purchase a trailer.
D
D.F.B
Australia
I only use push mowers out of preference, but most larger companies use zero-turns. A zero turn would mean a trailer, which also needs to be registered yearly. Storing a zero turn and a trailer would also present a problem as I have nowhere to park them overnight. I also hate towing with a passion. :ROFLMAO: I wouldn't be comfortable driving up on a set of ramps either.
Nothing against riders/zero turns, but considering size of the yards I do, the time saving across the day would be minimal.
D
D.F.B
Australia
Project S650 – 771 days in the making!
This all started in early September 2022 with Ford unveiling the new 7th Generation Mustang. At the time, I had been a Mustang owner since March 2017, in that time nothing else on the market really interested enough to buy something in the meantime. The updated 2018+ models certainly appealed, but not enough to trade up. So, with the reveal of the new model, I knew this would be a worthy update to a car that had stolen my heart.
After a week or so thinking it over, on the 21st of September 2022, I made a trip down to my local Ford dealer, the same that sold me my S550 and the last car I bought. At the time, the Ford showroom was being remodeled and so I made my way over to the adjacent VW building and asked for my usual salesman. Turns out he had left at the start of Covid, I told you it had been a long time! I was then directed to the temporary site-hut that was a makeshift Ford showroom, then handed over to a junior salesman..............what a baptism of fire for him!
Sitting in the makeshift showroom that morning, there was a lot of unknow playing out. For starters, at that stage no one knew anything about the S650 other than it was coming to Australia at some point. There was no confirmation of models, pricing, or when it would arrive. Dealers couldn’t even place an official order because there weren’t even any product codes to register against. So both the salesman and myself were in the dark. I didn’t learn this until last week, but my new salesman had only just started with the dealer, and this Mustang order was one of his first deals. After conferring with the sales manager, an old-school contract was doctored up to get myself in the system, which naturally was subject to change. Looking back, they used the S550 Mustang GT as an order template. I then paid a $1000 deposit, shook hands and left the dealership at the top of the dealers S650 order list.
And so began the wait. This was not my first rodeo, early on, S550 Mustang customers were waiting up to and beyond 12-months to get their car. In fact, I waited just that for mine, placing the order in March 2016 and taking delivery 12-months and 7 days later in 2017. So, you could say that I was well versed in waiting for Mustang’s. Being that I had effectively pre-ordered a yet to be confirmed new model, I was fully expecting to wait beyond 12-months. At the time, this didn’t bother me as I wasn’t yet ready to part with my S550, the extended wait would give me time to enjoy the car a while longer and plan for some extended holiday leave to coincide with the new cars arrival. The car or the holiday, it's hard to know which I wanted more.
The following two years were an exercise in frustration. (Keep in mind the following is two years' worth condensed in a paragraph, so my exact recollection might be hazy now) In early 2023, Ford asked dealers for a model mix to gauge/plan projected production. Customers were asked for preference of body, colour, engine and transmission. Model specs, options and prices were expected to be announced in the following month. And so began the agonizing torture Ford Australia inflicted on their most loyal of customers. In mid 2023, Ford released specs and options, with pricing expected to follow shortly after. What annoys me most during this time was how customers were not given a chance to properly order their cars, in fact NSC numbers and build slots were allocated BEFORE pricing was announced. My argument was that I had an order number and production slot for a car I had no idea what would cost me, or if my chosen spec had been accepted. And this was NOT a dealer thing, this was from Ford themselves, delivering ladder-frame pickup trucks was (and still is) their top priority.
Production of RHD export S650 Mustang’s were supposed commence in late 2023, with the first deliveries expected before Christmas. In October 2023, Ford FINALLY announced prices to stunned silence. As I had expected, Ford went in for the kill and jacked prices up to the teetering point where it was not too high to lose a customer, but high enough to cash in on the popularity of the Mustang. I get it, Ford is in business to make money, but the delays with pricing and then the massive price hike was pretty rude. In any case, I met with the salesman for the second time ever and finally had a number to work with.
Also announced that day, Ford again told customers that production of RHD Mustang’s was delayed until Q1 2024. Which then became Q2, which then became mid 2024. Somewhere in all of that, I was issued a new NSC, a VIN number and finally a production slot. And while this was happening, I was getting more and more agitated over taking long service leave. If the car had arrived as expected in late 2023, things perhaps wouldn’t have gotten so antsy. But after each delay, my patience got thinner and thinner, both with Ford and with work.
To be clear, this was not the dealer or salesman’s fault, they wanted to the car as much as I did. I did my best to not be pestering him on a weekly basis, which was very hard but I didn't want to be that customer. Ford have a long history of botched product launches in Australia, this S650 Mustang was no different. I debated writing about all of that in this post because of negative tone it brings, this post should be about positivity. However, it’s an integral part of the story and how it led me to this moment.
And so, lets get to the good stuff............................
In January 2024, I was issued a production slot, a Vin number and an expected ETA in early October. We had some meaningful progress at last! The car went into production on the 24th of April 2024, coming off the line on the 26th of April 2024. Nothing could take me down that, seeing "Off Line" on the Vista screenshot, it certainly made things real! The car hit “gate release” on the 28th of April, then compound entry on July 3rd. On the 26th of September, the car was loaded on Vessel Titania………………..a name that had a lot of people laughing at. As long as it didn’t live up to its unfortunate name, I didn’t care what boat it was on! From here, I tracked the vessel as it made its way down the east coast of American, through the Panama cannel, then on towards New Zealand and Australia. Once in Australian waters, the vessel travelled to Brisbane, Sydney and finally Melbourne where my car was unloaded on the 29th of September 2024.
The best moment of all arrived last week after standing in a que at the bank, always an exercise in frustration. On my way out, I took a glance at my phone and spotted something that took my breath away! Beaming back at me was single image with no words attached, I don’t think any were warranted. The pic in question was taken seconds after the car arrived off the truck. The funny thing is, I had planned on going to the dealer that morning to touch base, had I gone there first instead of the bank, I would have witnessed the car being driven off the truck. Finally, after 2 years and 25 days, my new Mustang was here! I think I will remember that day for a long, long time.
I then hightailed it to the dealer, walked through the glass doors and spotted my red beauty in the delivery bay. As the salesman approached me, I’m not going to lie, I was speechless and on the brink of tears. I know, it's just a car, but after such a long, long wait and all the **** that’s gone on in the background, it all of a sudden hit me that this was happening.
After a good look over the car, and even a cheeky start up and rev in Track mode, a delivery day was organized, an extra seven days in the grand scheme of things was nothing. Props to the salesman (again) for collecting all of the production line paperwork and window sticker before they went in the bin.
With two years in the lead up to delivery, I’ve had plenty of time to figure out number plates, detailing, wheels, exhaust, and various other little changes I wanted to make. The first of which was a set of black slimline plates with the Ford upgrade and a set of number plate mounting brackets. More on those at later date.
Over the following 7-days, I had been surprisingly calm. And its at this point I'm glad I took leave early, having some time to unwind has been working wonders. Having time to nail down insurance, funds transfer, all little things that would normally be stressing me out. Not this time. Actually, there was a brief blip at the bank when I was told they don't cut cheques anymore...................just shows how long it's been since I bought a car. :rolleyes:
And so, we arrive at delivery day...........................
D
D.F.B
Australia
Delivery Day!
My nerves were fine until last night, I started to get that heart flutter of anticipation and butterflies in my stomach. There is no reason for such a reaction, just something I have always had when I’m either dreading or anticipating something. I also didn’t get off to sleep as I would have liked, so my body wasn’t happy getting out of bed this morning. I had jokingly told the salesman that I would be camping in front of the showroom overnight, instead a rolled up 10-minutes late.
Jumping in my S550 for the last time, well it wasn’t as emotional as I had expected. I think I had reached contentment with the car a while ago, especially after writing down and publishing a lengthy love note, I sort of got it out of my system. Still, giving the throttle one last rev-match blip was sad. Driving a manual is an art form, coordinating hands and feet to achieve that perfect shift, well it played a huge part in how much fun I had in that car. Driving around the back of the dealership toward the delivery bay, I had an audience. The sales manager, detailer and my salesman greeted me as I stepped out of the S550………………they seemed as nervous as I was, which I’ll get to in a moment.
Stepping into the showroom, I was glad to get stuck into the formalities before the main event. The usual paperwork followed, the hardest of which was signing over the S550, suddenly it was no longer mine. But also suddenly, the S650 became mine. It was then time for the show. As you can see, my new Mustang had a stablemate to keep it company…………………………
I mentioned yesterday that I was asked about doing the “reveal”, and that a previous customer lost his temper over having his car covered up. To me, it might be a silly ritual, however buying a new car is not a regular occurrence for most of us, so why not? And so, off came the pretty blue bow, followed by the satin cover……………………..
That blue convertible is the dealer principles car, which eventually made way for a special moment. But not before the usual run-through of the car. I have to laugh, even though my early S550 had Sync 3, it was also refreshingly simple. This new car, it’s so complicated, exaggerated by everything being on the touchscreen. Still, I faked an interest in radar guided cruise control, the Ford Pass App and the myriad of active safety stuff. I don’t think anyone buys a Mustang for any of that ****, but if they didn’t include it, they would be crucified. I think the coolest part of all this tech is the ability to change the dial cluster screen appearance, which the salesman selecting the 1967 theme for handover. I think there may have been a little suppressed laughter when Kylie Minogue popped up on the screen after pairing my phone, even though I closed all of my apps to avoid such embarrassment. :rolleyes::ROFLMAO:
It was then time for a special moment that I had organized a couple of months ago……………………………
The S550 was last parked in that delivery bay back in March 2017, and its return today signaled the beginning of something new. By this stage, I had the sales manager, used car manager and my salesman gathered for this rare photo opportunity. Heavily biased of course, but the two made a good pair! But at the same time, it became extremely obvious how dated the S550 looks next to the S650. To be clear, I still think the S550 is the better design, they absolutely nailed the design of that car, the pumped-up hood and those heavily contoured body sides are perfection. The funny thing is, the rear end of the S650 had never really grabbed me, but it’s the area of the car that looks the most differentiated from its predecessor. And finally! Finally, we Aussies get the red taillights and not the tacky clear/white things of the S550.
At this point, I want to highlight the how amazing my salesman was during this journey. Often, we go about our jobs without knowing the impact it makes on the people around us. By simply doing his job, he made a dream come true! We also often go about our jobs without positive feedback, be that from the customer or those above us. I appreciated his patience and assistance as we both rode out this two-year journey. Next month, he too is going on extended leave, to get married no less. There was some worry that he wouldn’t get to follow through with the handover, which would have been a shame as he had done all the work. But in the end, it all fell into place. In the past two years, he has gone from a junior salesman to be an award-winning salesman. With how he treated me, he deserves every accolade and acknowledgement he gets. In summery, when someone does good, tell them! It makes a huge difference.
More than two years in the making, a lot of blood, sweat and tears to arrive at this moment. I dragged myself to the top of the mountain, the feeling of euphoria almost unbelievable. For those that read, commented and sent private messages, you too have helped me reach the summit. There might have been some drama along the way, I was close to quitting many times, but your words along the way made me hold on to the dream.
And so, just like that, I’m now an S650 Mustang owner.
