Did I mess up? Craftsman table saw
ARFLY
NW Arkansas
Found an old Craftsman table saw at a pawn shop today. It was an old Heritage series probably late 1940's. It had the motor with a new belt and a new blade. Also had the cast iron table extensions, the fence but a newer Delta guide. It didn't have the stand either. It was in decent shape, and they were asking $59.99. I offered $60 out the door and they load in the truck. They would not come off the sales tax which amounts to about $5, and they said they would help me get it in the truck but wouldn't load it for me. I told them they could keep it. Did I mess up on this or should I have gone ahead and grabbed it?
nine4gmc
Dallas
Tilt table or tilt arbor? If it was a tilt table I would pass, tilt arbor eh, the price is not bad but just depends on what you want/need it for. Also, pics would help a lot in this case. How was the motor mounted?
A
ARFLY
NW Arkansas
Looked to be a tilt arbor. The motor was mounted off the back side of the saw. The motor mount consisted of 2 steel rods that connected inside the cabinet under the saw with a mount that had the motor attached with 4 bolts. There was a tilt mechanism on the mount so the tension on the belt could be adjusted.
nine4gmc
Dallas
Gotcha, sounds like the standard tilt arbor model. Price is decent, I may have walked too with them not willing to work on the price, it's a damn pawn shop, they are supposed to haggle...
A
ARFLY
NW Arkansas
No kidding. I bet they don't have $20 in it.
zkling
If you need a table saw and it was the same one you linked, you should have bought it. They are pretty decent saws. In a way I think the 8" ones are more useful, due to the lack of power and motor location. The full size 10" ones take up the space as a cabinet saw.
woody 73
The Great State Up North
Funny story just today I was in a pawn shop and the very sweet pawn owner had a drill I was interested in marked at $39.00 dollars. Beat to hell and back, run over by a truck and kicked off a high rise it still sounded good. I smiled and said "Sir would you take $30.00 dollars for it".
Too which this very loving, kind, humble human being said..."It is marked at $39.00 dollars get the hell out of my shop".
I kid you not...:lol:
It is a wonder how these guys get away with that kind of ****?
A
ARFLY
NW Arkansas
After the initial shock, that would actually be pretty funny.
Shiftless
East Bay SFO
Wow! Is this a first? A GJ member who prefers something not only smaller but lacking power.:dunno:
I have a vintage '50s craftsman 10 inch saw with the 2 cast iron extensions. Sure, it takes up the same space as a cabinet saw but it sits on a custom stand I built featuring 4 inch rubber casters. Super convenient for me, a guy who has to wheel it outside to do work.
zkling
Untill you realize that the smaller diameter blade has more force at the tip to plow through the wood vs a larger under powered 10" blade. With the 1hp iirc motor on there it will rip any 2" hardwood. Space efficiency wise a cabinet saw will usually take up less space than a 10" contractor (motor out the back style) saw. You can put a cabinet saw on wheels and actually move it around easier than a contractor style due to weight distribution.
Shiftless
East Bay SFO
Good point. With identical motors, the 8 inch blade will exert more force to do the wood cutting and will be less likely to stall. But at the same rpm, the 10 inch blade will have a greater velocity at the edge which with a fine tooth blade might make a difference in the resulting cut.
exmaxima1
Midwest
Exactly. And if you adjust the pulley sizes so that both blades have the same tip velocity (about 4000 rpm on the 8-inch blade), the torque values come out the same.
