Did It Myself Lista Tool Box
Bib Overalls
Jonesboro, Arkansas
36346762791_076310b3e5_z.jpgLista Mobile Tool Box 01 by Formerly JimboT, on Flickr
Several months ago I found this Lista cabinet on Craigslist. I had my friend Ben at MMS Powder Coating and Sandblasting make it red. I put it on some casters and stepped back and gave it a long look. I didn't like it.
36346760101_b97b339562_b.jpgLista Mobile Tool Box 03 by Formerly JimboT, on Flickr
So I looked around the shop and spied this Lista cabinet that I have had for years. Same drawers, same height and same width. What if I bolted them together and it all up on casters? The answer; a high end lista roll around tool box and a nice work top.
36346757841_5f6559a249_c.jpgLista Mobile Tool Box 04 by Formerly JimboT, on Flickr
Further, I could swap out drawers with this other Lista cabinet as needed to get the arrangement I wanted for the tool box.
36346750711_3673d4f614_c.jpgLista Mobile Tool Box 05 by Formerly JimboT, on Flickr
First step was to order a stick of heavy angle iron.
36087082390_d9b63dd785_c.jpgLista Mobile Tool Box 06 by Formerly JimboT, on Flickr
Over the years I have tried any number of techniques to make 90 degree angle iron corners. This works best for me. All cuts were finalized on the mill. This keeps everything square and tight for welding.
36346741281_6baf9ab8eb_c.jpgLista Mobile Tool Box 07 by Formerly JimboT, on Flickr
I used a corner vice from Grizzly Tool to set everything square and weld ready.
36346738801_e3ca6568dd_c.jpgLista Mobile Tool Box 08 by Formerly JimboT, on Flickr
Finished corner is strong and looks good. A little grinding on the top and the joint is finished.
35648836994_3396345abc_c.jpgLista Mobile Tool Box 09 by Formerly JimboT, on Flickr
Here is the frame before we welded in the center crossmember. Overkill? Maybe but it is not like we will be picking it up all the time and it will be on casters.
36315652702_92b1703b93_c.jpgLista Mobile Tool Box 10 by Formerly JimboT, on Flickr
Frame back from Ben at MMC with casters bolted on. Ilike red.
35675576853_b46ec1c07e_c.jpgLista Mobile Tool Box 11 by Formerly JimboT, on Flickr
The larger cabinet got the treatment at the same time.
35675575633_dbaf0a79af_c.jpgLista Mobile Tool Box 12 by Formerly JimboT, on Flickr
Now for the top. I used a sheet of 12 Gauge stainless steel because I had it.
35675574733_112c739c29_c.jpgLista Mobile Tool Box 13 by Formerly JimboT, on Flickr
The only means of cutting material that thick and that hard that I is a skill saw with an abrasive metal cutting disc. I expose the blade about 1/4 of an inch and make multiple passes. If you try to make it in one pass your disc will wander and eventually fail.
36346722561_13e78eafc9_c.jpgLista Mobile Tool Box 14 by Formerly JimboT, on Flickr
To hold it in place I positioned the top final and clamped it in place. Then I drilled eight small holes and taped them 10-24. When I lifted the top I drilled the holes in the cabinets to pass a 10-24 stainless machine screw. My friend Randy removed the screw heads positioned the screws to his liking.
36346721101_1ce49813ec_c.jpgLista Mobile Tool Box 15 by Formerly JimboT, on Flickr
Then he TIG welded them in place. When the work surface was placed on the cabinets it fit like a tailor made condom.
35675571453_edb5eb403f_c.jpgLista Mobile Tool Box 16 by Formerly JimboT, on Flickr
Lista no longer supports their older cabinets. One important feature of Lista cabinets is their system to lock the drawers in place and only allow one drawer to open at a time.. Without these plastic latches the system does not work. The latch on the left is brittle and it has broken. Worthless. The latch in the center is good but no longer available from Lista. The latch on the right is the only replacement I have found. They are available on eBay in lots of 5 for $25 plus shipping. A tad high but the only solution available for replacing broken factory latches.
35675570393_dbbf351273_c.jpgLista Mobile Tool Box 17 by Formerly JimboT, on Flickr
The latches are clamped in place, drilled and secured with two pop rivets.
36346717871_e3def39d6d_c.jpgLista Mobile Tool Box 18 by Formerly JimboT, on Flickr
The only thing left to do is replace one of the locking cylinders and it will be ready for tools.
35675567823_76fbe2367e_c.jpgLista Mobile Tool Box 19 by Formerly JimboT, on Flickr
I would like to add push/pull handles on the ends at some point but they are not essential and may never never happen.
CNGsaves
KS and OK
That is EXCELLENT workmanship and outcome you've got there Bib !! :thumbup:
Like the matching of red for toolboxes to the inner red of '32 Ford wheels. :D
More PICS of the cool car ???
jon72vega
Niles Michigan
Bib Overalls,
That is sweet!
I don't know if you saw the below info on my Lista thread or not.
I got a lock # IC-CYL-RG (it comes with keys), and adapter plate # X4414 from:
DMARK Corporation
10552 Humbolt St.
Los Alamitos, CA 90720
Tel (562) 799-9010 / 888.897.9050
They are a distributor for Lista.
Everything was shipped direct from Lista, and I received them in around a week.
Bib Overalls
Jonesboro, Arkansas
Great Fabrication job! How deep are the drawers?
Todd
If you are talking front to back about 28".
If you are talking face depth the top 4 drawers are 2" deep, the next 4 are 3" deep and the next 2 are 5" deep. On the left the bottom drawer is 8" deep and on the right the bottom 2 drawers are 4" deep.
I have some 1" drawers that would fit on the right side but they are not good for holding anything but pencils and center punches.
Bib Overalls
Jonesboro, Arkansas
My thanks to everyone who replied and to all of the 1,300+ folks who have taken a look so far.
Laying out the angle iron corner cuts is easy.
Side rails (length and width) are cut short by two times the metal thickness. Example: If you are using 2"x2"x3/16" and you want a 24" side rail you would cut at 23 5/8".
Two of the side rails (left and right or front and back) are notched. The cut is width of the material less the thickness of the material. So, carrying forward our example you would cut 23 13/16 in. The notch is completed with a cut from the end to the cross cut releasing the flap.
I do this work on my mill mostly because I have it and I can make precision cuts. The better the cuts (square and on the mark) the better your result. You can make adequate cuts with an abrasive chop saw, horizontal band saw, angle grinder, etc.
You can fit it all together with a framing square, clamps and some lengths of angle iron.However, you will make a truer joint if you have a welder's 90 degree clamp.
Good luck!
tarmy
Nor Cal
Forget the box...your weld fab up prep is inspiring...
Never seen any mill corners so clean like that...but as you have learned, as have I, the prep effort is what makes the results...
Oh...the cabinet thingy looks okay too....
bbqandbrew
pigs eye, mn
I was talking Front to Back. I really like a drawer depth on 24 inches. My Craftsman toolbox is only 18 inches deep and I want to build a toolbox that has 24 inch drawers.
Thanks again for posting and answering my question.
