die grinder disc holder with hex shaft?
bbs lm-r
I'm searching for a tool that I'm not even sure exists. Maybe I'm just searching under the wrong name.
I'm looking for a die grinder disc holder with a hex shaped shaft, to be able to use grinding discs with a drill instead.
Feel free to point and laugh if this sounds stupid. Thanks
zkling
They have them at lowes, can't find them online ATM. From my experience, do yourself and your drill a favor,go get a dremel and or a 4.5" grinder.
APEowner
Sunny, New Mexico
A round shaft will chuck up just fine in a quality drill chuck however, die grinders run at a much higher speed so you might not get good results with a disc in a drill.
Also, cutting discs don't flex and the weight of the drill might make it hard to tell when you're putting a side load on the disc.
OctoMan
Newport News, VA
Dremel makes a flexible shaft. My experience has been that a drill motor doesn't have enough rpms for most jobs. That being said if you use a good 3/8 corded drill it may work well.
OctoMan
Newport News, VA
Air grinders and the Dremel run around 30,000 rpm 3,500 for
A drill motor. Craftsman used to make a great electric die grinder but they discontinued it. If you can find a used one they're a great tool.
larryforce
As others have said a drill has a much lower rim, but at the same time you can put a little more weight (force?) Behind it to get a similar result. I needed a to use some roloc disks to where I didn't have air and the holder worked great in my m12 cordless drill. It was a little slower but functioned well.
That being said if money is no object Milwaukee has the cordless polisher now
bbs lm-r
Yeah I wouldn't use a cutting wheels on it, just normal die grinder discs for light-duty work. In case anyone's still wondering, yes this scenario is due to the lack of air for said die grinder.
Also I just found that ACDelco makes electric/cordless die grinders, although they're a bit pricey. Quality wise I'm not too worried, I've been using their 1/2 impact, 3/8 impact and 1/4 ratchet, all electric/cordless with no problems.
