I welded up a simple wall-mounted right-angle grinder bracket that has worked great for years. However, I've never found a good way to store my die-grinder (straight, not right-angle). I thought about some plate steel with a hole in it big enough to drop the collet end through and have it stand up vertically on the wall, however mine has a rubber hand grip/gasket in that area (see picture below) I'm afraid would take a beating. Though, it would probably be fine if I chamfered the edge of the hole. Has anyone else found a good way to store a straight die grinder up on the wall?
