I have a no-name DG I use from time to time. It is really easy to bog down so cutting is pretty slow. I have a vertical compressor with a large tank, 175psi. Are die grinders different from Mfg to Mfg? Do some have more umph?
I have a few extra 3/8 couplings and plugs. I use them on some spray equipment and a fresh air delivery system. Makes sense, I'll try it out and see if it makes a difference. Thanks for tip.
Im not sure I follow. HD has a "3/8" set but the description still claims 1/4" fittings.
http://www.homedepot.com/p/Husky-5-...tyle-Quick-Connector-Kit-HDA20700AV/100079135
As said above, 3/8 coupling (bottom) has larger body than 1/4 coupling (top). Both are threaded to fit 1/4 FPT on your air tool.
^^ Yes exactly. I would like to see the 3 Milton plugs mentioned above lined up next to each other. How a 1/4" v fitting flows more air than a 3/8" fitting is beyond me. Unless the inside diameters are exactly same size and the coupling is different.
what is the cheapest place to get milton V fittings?
OK, so they are basically 3/8" body couplers. Thanks for the pics. I think the Milton stuff is over priced. You can get some cheap 3/8" body automotive plugs from Speedaire or even the ones from Home Depot for much cheaper imo. Plus, this is just a test to see if it improves the die grinder the op is talking about. Buy the cheapo HD set before you put big bucks into replacing all the fittings with something else.
Milton V ******* are only $0.77 and the couplers are $4.48, not that over priced compared to the HD ones. And the nice thing about the Milon V style couplers is that they also accept Milton M style *******. So if your already running an M style ******, you only have to switch the high usage tools over to the V's.
I upgraded all my fittings to 1/4" thread x 3/8" body automotive coupling plugs. Then I did a comparison test with one of my impacts on a lug nut. Both nuts torqued to same specs using my snappy mg725, the bigger fittings made a ridiculous difference. The gun used to hammer a bit first, now it blows the lugs off with a tap of the trigger. Grainger had sales on the couplings and plugs at 19 cents each. I bought as many as I could. Now every tool I own has 3/8" body coupling plugs. You can buy a set of coupling plugs and quick release coupler for cheap from HD of tractor supply to test it out before deciding if you need a bigger compressor.
Sold, because I currently use M connectors. I really don't want to change out 100 connectors
Do you have a link for the 77 cent connectors?
The Milton M's do not fit as tight into a V coupler as a V ****** would fit into a V coupler, or an M ****** would fit into a M ******, but they do fit...
We have a winner! I stopped by and picked up a 3/8 set from HD and holy moly what a difference. I will have to turn it down to use it! I can't wait to try my impact.
Hope this isn't off topic.
I purchased some surplus file storage cabinets from work a couple months ago. These came from our Die Shop. One drawer was nearly full of die grinders. I have both straight shaft and angled type. Once I have some time to sort out what they really are and if they work, I was thinking of selling most of them on here or ebay.
I think there are a couple rebuild kits thrown in there too. My guess is that they all probably have some problem, but not sure.
https://www.jbtoolsales.com/milton-760-hi-flo-v-style-1-4-mnpt-brass/
These are the male thread *******.
https://www.jbtoolsales.com/milton-764-hi-flo-v-style-a-m-v-1-4-fn/
These are the female thread couplers.
JB has other variations, you will just have to do a little looking. Or Milton has a good website, check that out to get the part numbers.
http://www.miltonindustries.com/couplers-and-plugs/v-style.html
