RTcat
Okay, the more I dig into potential coverings for my fresh, virgin concrete floor, the more confused I get
What is the difference between the "epoxies" sold by the vendors on this site and Polyurea?
Christine, Scotty and the other vendors...do you sell a Polyurea?
Can I simply put down Polyurea and call it good to go?
Below is a product I found while searching the net for concreate floor coverings. I'm curious how this (Polyurea) stacks up against an Epoxy...
xxxx is a two-part, high solids, high build sealer designed for use on concrete or masonry surfaces. xxxxx allows for single coat high film thickness in a water clear finish. xxxx provides a very smooth, mirror like finish not attainable with any other product. In addition, xxxx does not yellow or deteriorate under UV rays, it is highly resistant to chemicals and will greatly increase the useful life of any surface it’s applied on.
xxxx is a Polyurea sealer made with premium resins, it is non-yellowing and resistant to oil, gasoline, grease, acid, deicing salts, ultra violet rays, wet and dry abrasion, and most household chemicals. xxxx contains unique resins and solvent formulations designed for maximum penetration into the concrete pores providing great adhesion to the surface. It enhances the depth and color of natural surfaces and provides a long lasting protective, mirror like finish that’s ideal for decorative concrete surfaces.
TECHNICAL DATA AND SPECIFICATIONS
Coverage Rate ...............................................200 to 400 ft2 per kit
Packaging ......................................................................2 gallon Kit
VOC .............................................................................0 Gms x liter
Color ..............................................................................Water clear
Water Miscible ............................................................................No
Solids ......................................................................................65 %
Shelf Life ................................................................................1 year
Recoat Time ................................................................2 to 4 hours
Application Temperature .............................................35°F to 85°F
Flash Point ...........................................................................114 ° F
CHEMICAL RESISTANCE
Reagent: Rating:
Transmission Fluid ............................................................No effect
Gasoline ............................................................................No Effect
Motor Oil ...........................................................................No effect
5% Sulfuric Acid ...............................................................No effect
30% Hydrochloric Acid .....................................................No effect
Detergent ..........................................................................No effect
.What is the difference between the "epoxies" sold by the vendors on this site and Polyurea?
CHEMICAL RESISTANCE
Reagent: Rating:
