fourstringriot
Hi Everyone, long time reader - first time posting. The information I've gathered off this site has proven to be invaluable and has given me enough confidence to move forward with a project I inherited when I purchased my home. As you can probably read into from my details below I do not pride myself on my carpentry skills or language, so bear with me.
Here is my situation... the previous HO built a post & beam structure 28x24. He framed out 3 stalls with the 6x6's for 9x7 doors but only put a sliding barn door in the middle stall. I'm now at a point where I've poured a slab and would like to put overhead doors in the middle stall and stall next to it (to the right in the picture below, left stall will be a man door). The overhead garage door company I had come out stated that they could do a 9x7 in the middle, but wanted me to frame in the second stall for an 8x7 so they had a place to run the rails (the gable end of the garage is built using horizontal 2x6's and siding on top of plywood, the rest of the garage is covered in 10" wide pine boards.
So the question is this - if I have a 9x7 and an 8x7 next to each other, will it look funny? Keep in mind I also have the cropped angles at the top of the door, but both doors will be the same height. I also don't want to make both doors 8x7 as I need to fit my truck in the garage and that's already a tight fit. I realize it's a garage, but it's also one of the first things you see when pulling up to the house. Short story, if i win with doors and lose with the wife I am no better off, so it has to look right.
Sorry for the novel, thanks for the input.
