cvairwerks
Never seen one that does 0-50 lb\in.... and is less than 8" long.Some electronic can vibrate, but the click-over is very obvious even with your eyes closed and ear muffs on.
Definitely on the size. We have one location that we regularly have to torque an item that is so tight that it's generally done by pushing on the torque wrench with a couple of finger tips. Opposite side of the airplane and you use a piece of string tie to pull the wrench. Access is so tight that the wrench is generally held in place with one or two fingers and then pushed by one or two of the opposite hand. We've got a few guys that can't even get a hand in to put the wrench in place.I have a 12" that does 20-300? It's the newer metal body tech angle.
You're 100% right, mechanical is often smaller. Big advantage depending on application.
Nope. Often, we have very limited space for equipment on aircraft. There are installations that have to be removed to gain access to other installations....nature of the beast.Sounds like it was designed improperly. LOL
Well, if the engineers did their homework correctly, the angle spec should always be a multiple of 60 or 90 degrees. Which means just so many flats on the hex (mark it) or half-rotations.You can download an angle finder app free on any smart phone to find X degrees past torque value. May be a touch awkward to hold it next to the torque wrench, but it works.
Right, but the higher number of degrees of rotation is designed to split the torgue and angle in such a way that biases it more towards the angle. The more angle and the lower the torque, the more precise and consistent the amount of stretch is. This is why you see angles like 270 and I don't think the specs I've seen or developed really considered whether it was all in one go or involved a ratchet or such.You can buy really cheap and reasonably accurate angle displacement gauges or extensions - but what is far more important to appreciate IMHO is that once you start from the pre-torque position you need to keep moving at a constant rate to the angular target. Slip/stick events can leave you in the wrong place by a fair bit. This is my biggest ***** about specs that are something like 270 degrees - almost impossible to do reaching into an engine bay without stopping at least once.
Torque plus angle is a big improvement over straight torque, but we're still talking ±15% variation vs ±30%. So while torque+angle is twice as precise as straight torque, it's still pretty terrible overall in terms of tension consistency.
Certainly terrible enough that a couple degrees of variation in your tightening is not consequential.
I am just a DIY mechanic though I have done a lot over time.What are peoples opinions of digital vs mechanical torque wrenches? I'm in the market for a torque wrench (maybe 2) that I can trust.
I've read around a bit and I see people recommending the CDI, the PI, the Snap-On, etc.
I see people saying their $20 harbor freight is just as good. I don't see much recommendation of digital.
Currently, I have a 1/4 Tekton 20-200 in lb, wrench that I use for torqueing belly pans, and intake gaskets, valve covers etc. I have no idea if I can trust it, but nothing has leaked so far and its solved my problems. I also have an ACDelco 1/2 14.4-150 digital adapter I use for torquing lugs.
I've read so many varying opinions on what is good and what isn't I have no idea at this point, what to buy. I have a hard time buying Icon just because harbor freight, but didn't hesitate to buy a US General 5 drawer cart from them (which is awesome). As an example, some people have nothing but bad things to say about PI (over torqing bolts etc), while most say they're great.. So which is it? I'm guessing those people just don't know what their doing?
I am looking for a 1/2 and maybe even a 3/8 so I can bridge the gap between the 16.6 lbfts of the 1/4 and the common 30 ftlbs of most 1/2 wrenches.
I am leaning away from digital because batteries sound annoying, however if they are more accurate for the lifespan of the tool, then I'll go that route I suppose. I am a diyier, non-pro, who does all the maintenance on my truck and sedan. I enjoy the work and challenge, but I don't want to be out fixing **** every weekend if you know what I mean. I do like quality tools, but I understand there is a middle ground. Prefer made in usa, but sometimes that is out of the budget. Hopefully that paints the picture. I just care about a tool that does the job well everytime I need it to.
