Disconnect 30 amp dryer circuit?
Status
Not open for further replies.
enochian
My dad told the builder to put in a gas line AND 30 amp electrical circuit for the dryer.
The 30 amp dryer circuit seems like a waste.
Disconnect or leave?
Norcal
Why? Not hurting anything,I put in a stub for a gas dryer 29 years ago in the utility room it is fine, been untouched all these years & the same applies to a dryer receptacle, if your worried just leave the breaker off.
sparky 1971
Central Iowa
For the range, some like a "dual fuel" product,range w/a gas cooktop & electric oven.
Which is exactly what I have now. Gas top, electric oven, and a built in down draft vent. Talk about a ***** to install.
I sold the house that had the electric pre wired
Norcal
I heat water & the house with gas, dryer & range is electric, even took the gas out of both kitchens on the property.
LopezBart
Lopez Island, WA
We use a heat-pump dryer; it's run by electricity, and is ventless - no more dryer vent lint fires. Gas appliances may not be a thing in 20 years, or it may be quite cost effective to ditch the old gas dryer.
BrandonV
Arizona
Interesting. Never seen one of those
Very popular in Europe. No vent needed as they discharge into your drain to remove water instead of using hot air. Only downside is they're pretty complicated internally and more prone to failure.
Personally I don't like gas appliances except for cooking. No way I'd remove the ability for the next owner to use an electric dryer.
BrandonV
Arizona
I want to add a 60 amp EV circuit.
I have 400 amp service.
Do you not have any room in the panel? If that is the case I could understand disconnecting the dryer from the panel while leaving the receptacle in place.
that was gonna be my next question- how does it remove the water.
I love gas appliances here in commiefornia where electricity is super expensive
It is starting to happen. It is also starting in BC Canada in 2027
https://www.google.com/search?q=hav...xODQ1MGowajeoAgCwAgA&sourceid=chrome&ie=UTF-8
You said starting to. No it hasnt started. Your link says 2030. Keep in mind i live here. I can walk into HD right now and buy any gas appliance.
Also the previous gas stove ban was thrown out earlier this year. The same will happen for the water heaters and furnace ban.
It will get thrown out because you cant make it mandatory for grandfathered install (existing home) required to run new circuits for appliances. In Some homes that would be super expensive to do so.
Pacific Graft & Extortion is raising electric rates around 25% in January.
Bummer
Our local is raising rates for the first time since 2012. The flat rate meter fee did go up last year however.
Theyre facing a $40mil shortfall due to the huge rise in NG prices
LopezBart
Lopez Island, WA
They've repeatedly spent monies that earmarked for pipeline and transmission line safety and maintenance on other things, including executive bonuses. They lost massive lawsuits after it was shown that their failure to maintain clear areas around the electric transmission lines caused some of California's worst wildfires when windstorms hit in the fall (fire season). They're now raising rates to cover the damage assessments, and the rate payers get screwed again. They've been very effective at regulatory capture, being able to have friends on the PUC that are sympathetic with PG&E's viewpoints.
rancherbill
Foothills County, Alberta, Canada
There is always a grandfathering provision or there should be. The way BC, Canada is doing it is via the building code. They are simply not allowing them in new construction.
Reading about the health effects of natural gas, in this old article, I am surprised they are still sold. I am a cancer survivor and it surprising to learn the gas stove in my house is leaking carcinogens.
On the original topic, it is smart to leave the plug.
https://www.fatherly.com/news/natural-gas-ban-california-appliances
almost everything has carcinogens in it or leaking from it. that hash brown you ate from McD? yeah it has carcinogens. That coffee you bought at Starbucks? yeah it has carcinogens in it. That truck you drove behind with your windows down was emitting carcinogens that blew into your car.... we could go on and on
sparky 1971
Central Iowa
Almost everyone I hear talking about the dangers of gas justifying refusing gas cooking and dryers have a gas furnace and 75% of the time, water heater. I can't speak for everywhere, but here it's still more economical to make heat with gas vs. electricity. I have the gas lines run in preparation for the days my water heater and dryer shoot craps. The only reason I have an electric oven is because I have a slide in with a down draft and it's only available as dual fuel or all electric.
rancherbill
What's your point? Are we supposed to ignore science?
Jmellc
Durham, NC
Keep both for sure. I am an electrician & I can tell you it’s much cheaper todo it now than add it later. As others have said, a future buyer may not want gas; some people are afraid of it. Also true about gas appliances being restricted. Keeping options open is always a good thing.
Norcal
Science is so politicized that have to be really careful on what you follow, I don't like gas ranges because they are dirty, but like the plastic straw "studies" those gas studies were based on other very feeble studies. (I am mentioning my bias).
Status
