DISGUSTING THREAD- RAT URINE
kd3pc
Northern Neck
keep in mind that rats carry all sorts of disease, even plague and typhoid. Be careful with the clean up process.
PoorUB
Fargo, ND
I wasn't suggesting using toilet bowl cleaner on the urine spot. I was merely pointing out that bleach is used in a product that can be mixed with urine. If it's a huge issue, then Clorox is tying their own noose and walking to the gallows.
Nor did I say to dump copious amounts of bleach on the floor. If the OP has any doubts about how much to use, he can follow the link from the CDC I posted above about cleaning rodent messes.
Geez, Dude, if you don't believe it, Google bleach and urine, It should keep you busy for a while.
PlanB
Saskatchewan
The immediate solution to problems is soap and water, possibly with scrub brush and pressure washer.
As for bleach, it will liberate chlorine gas if the pH is dropped (ie exposed the urine). Keep the door open and it probably won't be that big a deal ( for heavens sake, it is smells open door and leave).
Long term solution is cat.
Now let's get back to arguing, err discussing, tourque wrenches and screw drivers
R
rockwind1
las vegas
the problem with cats is they don't just eat the bad animals,, they kill everything else that moves, pretty soon i will not have any lizards and songbirds. imo.
kwb
PNW
For the love of all things:rolleyes: - it is a concrete floor in an empty shop.
Get the garden hose rinse it down a bit, if it doesn't wash away use a scrub brush or even just your push broom to agitate it a bit and rinse it again.
This thread has more time invested in it than time it would take to clean it up.
Shiftless
East Bay SFO
kwb said…
“This thread has more time invested in it than time it would take to clean it up.”
Truer words have never been spoken. 🍻
Kuma601
Cali
TSP works great for range of cleaning but as above, it is not available in CA among MANY other chemicals that used to be.
We've used white vinegar on pet urine and it is cheap. If it doesn't work then move up the ladder to some of the enzyme type cleaners. We've not had an issue with an application or two of vinegar. There are stronger vinegars but using them one has to take measures as it is an acid so may cause burns. Wear appropriate PPE when handling. The 5% stuff will dry your hands out.
May give this place a call and see what they suggest. There will be other chemical suppliers that will offer similar so you can buy locally:
https://www.maintex.com/home.do
Their product lines:
R
rockwind1
las vegas
i would like to say,, pretty much did that and those stains are into the concrete,, not as easy as it sounds if you want the stain to go away. using the enzyme stuff to see how it works.
