Dividers, compass, trammels, associated tools, (not calipers)
Eric Brown
This thread is about dividers, compass's, trammels and associated tools. Basically pointy things that aren't calipers.
Starting with some Stoddard's. 1872 and 1885 models. The 1872 uses tapered threads and matching nuts to hold the points or pencils. The 1885 version adds articulated legs. An excellent reference for these is at: https://allencompassingdividers.blogspot.com/2022/02/
  • US130879 Stoddard Dividers 1872.pdf
  • US314625 Stoddard 1885.pdf
E
Eric Brown
A couple of Millers patent dividers patented Mar. 31, 1874 and Nov. 11, 1874 for the cam like nut that secures the point.
Made by Det Bevel & Divider, Detroit MI.
  • US144468 Miller Divider 1873.pdf
  • US149052 Millers Dividers 1874.pdf
E
Eric Brown
Eagle dividers patented 1894. These have a very ornate body. Very lightweight. Has removable ends with points, lead and ink tips.
  • US530680 Eagle Dividers 1894.pdf
E
Eric Brown
Fulton dividers. The first two are both marked Fulton 202 but obviously different lengths. They are marked Germany on the reverse side. Probably made by/for United Hardware. The next set is marked Fulton Made in USA. What makes these unique is that instead of a spring to keep adjustments smooth, it uses a special knob that has both a right-hand thread and a internal left-hand thread. Last is a Fulton USA compass.
ararat
Ararat NC
Thanks for starting this thread, should be interesting.
Some of the images are not showing though.
E
Eric Brown
Millers-Falls dividers. First one is an earlier plated version marked Millers-Falls GFLD MASS USA. The second one is similar but is simply marked MF Co USA and has a black finish.
E
Eric Brown
Lowentraut MFG Co. Newark NJ Made in America, Forged dividers. 8" size.
E
Eric Brown
Leytool Micro-divider setter. Briton and US 1952 patents. Used to precisely set your dividers.
  • US2659977 Leytool 1952.pdf
E
Eric Brown
Proportional dividers. By moving the pivot different ratios can be made. Note the body does have a scale. Not marked but in a nice lined case. Looks manufactured.
E
Eric Brown
Sector made by Brendan Gaffney under BurnHeart name. Serial #137. Very nicely made.
E
Eric Brown
Set of thee Walke-Moore tools for providing pivot points. Inside, outside, corner, middle. Note the scalloped areas giving references for alignment. Non-slip surface on back.
E
Eric Brown
Another unknown trammel but with fine adjust and two rods. Looks like it was made by a good machinist.
E
Eric Brown
Some modern cheap ones, but they work. Made of aluminum.
E
Eric Brown
Keuffel & Esser Co St. Louis, Chicago, New York USA trammel set with multi tips and fine adjust.
E
Eric Brown
C.F. Pease Company Chicago #588 trammel set. Multi tip, fine adjust.
E
Eric Brown
Some of the images are PDF downloads of patent files. Hope that is what you are referring to.
E
Eric Brown
Is that the same Miller that had some plane patents?
No, different Miller. This one (George C. Miller) only has three patents listed on DATAMP.ORG and it shows he lived in Detroit and assigned his divider patents to James C. Maloy of Oil City Pennsylvania.
E
Eric Brown
Some info on Starrett dividers on GG.
Great idea for a thread. Way too much goodness to read on my phone though.
I'll start gathering up some of my goodies for some pictures as well
ararat
Ararat NC
Here's some curved trammels. Any ideas on what they would be for? Not mine, saw them online.
E
Eric Brown
Eclipse trammel set with box. Point can be replaced with pencil.
ararat
Ararat NC
I just skimmed over this post without zooming in. After further review, they are very nice. Are they nickel plated brass with some of the plating worn off?
Neighbor
Patternmakers would use them for measuring and laying against a shrink ruler. Often used in turning large items on a lathe. The curved points would either both face each other or both go away (for inside diameter)
E
Eric Brown
Yes you are correct. Brass that was nickel plated.
MShaw
York, Pa.
Two sets of drafting tools that belonged to my grandfather which would probably put them prior to 1920. No markings on them other than a DRP number on the ones on the right.
