kelpaso1
MEMBER EMERITUS
I work on ATV's in my own 1 man shop. When it comes to bleeding/flushing brakes it's a PITA all by myself. I have the MityVac suction bleeder and not a real fan of it (the vac pump is good though)
I had this thought before and while searching I came across a aircraft maintenence thread and found out that aircraft brakes are REVERSE pressure bled from the calipers to the M/C. I know I can make a normal pressure bleeder but I would have to have a separate M/C cover for each different makes of bikes.
My idea is this. Get a small 1 L pump garden sprayer. Fill with brake fluid. Adapt the hose coming out of the sprayer with a small ball valve to control the flow. Add silicone tubing to the other side of the valve which you push onto the end of the bleeder screw. Pump up the sprayer to a few psi. **** out the old fluid from the mc. Then open the bleeder a crack, open the ball valve a bit to get the fluid pushing up to the MC and keep using a syringe to keep sucking out the fluid in the MC until it is coming out clear. When it does repeat for all the other calipers/WH/CYL's.
Sound like this would work?
Also I never thought of using them for other fluids. Gear oil, trans fluid, antifreeze etc. Alot of ATV's are a pain trying to add fluids after draining. I think I be stopping by Amazon tomorrow
