DIY thread tap when your in a bind.
454ragtop
Carver, MA
Good video, I've done that before myself. One thing though, you show a 3/8-16 bolt to rethread a 12MM hole, won't work, 3/8 is smaller. Gonna guess you probably actually used 1/2-13.
Jim
rsanter
visalia ca
I did that many times back before I had a thread chaser set.
Depending on how you do,your slots you can make it work a couple of ways.
One way you grind it, it will help,to,reform the threads like a chaser does.
But you can also grind it with more of an edge like a tap to clean out gunked up,threads.
To make it work,properly. Or the best it can. You need to,use a minimum of a grade8 bolt but better you can use an Allen bolt as they have more case hardness to them
Bob
J
jerseykat1
Central New Jersey
To make it work,properly. Or the best it can. You need to,use a minimum of a grade 8 bolt but better you can use an Allen bolt as they have more case hardness to them
Bob
great advice using the Allen bolts.
ngk22r
The best option is to install a time sert for the aluminum oil of a Handa and can be installed without taking off the oil pan.
Your method is good as a temporary fix to get the person down the road. Overtime the new bolt will end up failing and even with a washer will start to form a drip and then the hole will wear out.
