Do I need full height blocking?
bluedog225
Texas
These are 16 inch LVLs that make up my roof rafters. 24” on center. Each blocking has two 3” inch holes in it for ventilation below the roof deck and above the 14” planned insulation. It’s only a 1:12 slope so I’m a little worried about getting adequate airflow.
Each bay is served by hardie soffit. I’ve done the math and the double 3” holes have greater area than the related length of soffit vent.
I’d still like to open up the area between the two holes. Less resistance to airflow would be better. This blocking is at every bay in the 25’x25’ structure.
Everything I can find says blocking should be full height and in full contact with the deck above. The reasoning is over my head.
What do guys think? It would be a simple matter to sawzall the middle section out. It is not connected to the deck.
Thanks
GrayFlattop
Chicago
If your area calculations are correct, I don’t know why you would need/want to do additional work. Unless the AHJ has a different idea.
Drill a third hole if you are worried.
PopcornSutton
Northern Tip of VA
Over the years in construction, every time the need to drill or bore through a beam came up, the rule was mid span/mid depth. That effects less of the stresses the beam is carrying.
I can see the holes against the deck for airflow, but if you want to move more air, I would bore it in the middle both ways.
racecougar
Missouri
Won't that be blocked by insulation?
bluedog225
Texas
To be clear, the piece with holes in it is about 23“ long. Blocking, not a beam. And while I agree that any hole should be located in the middle, I don’t think that rule applies here.
I also have blocking at the midpoint of these 25’ rafters. I used 14” LVL for that blocking. Leaving the top 2” open.
I’m interesting in understanding if and why blocking needs to be full height. And if that guidance applies in this situation where the rafters are fairly substantial.
Thanks
