Gotcha, just attic above. Do I call an engineer? Structural?
Oh my yes, X 1000, you need that. I don't even need to see what it's holding up
I suspect it would need to stay, depending on what is above there...Based on room dimensions, I suspect that whatever structure is above that, started to sag, or was quite bouncy, so the homebrew beam.
I dont see how anyone can say it is required without seeing what is in the attic. I have a similar beam that I installed for the same exact reason (engine removal) in my 22x22 attached garage except I built it so the support post could swivel up out of the way. The garage has a truss roof and does not need any type of support at all. So everyone that is saying it is needed would look at mine and say the same thing.
Bottom line is without looking in the attic there is no way to know.
i dont see how anyone can say it is required without seeing what is in the attic. I have a similar beam that i installed for the same exact reason (engine removal) in my 22x22 attached garage except i built it so the support post could swivel up out of the way. The garage has a truss roof and does not need any type of support at all. So everyone that is saying it is needed would look at mine and say the same thing.
I love all of the non engineers says that there is no way to tell.
Then someone that actually does this stuff jumps in and says it is needed.
Ah the internet
Ah the internet
it's easy; look at the original plans!
It's needed and it's almost certainly original. The tip off to this is that if you look at the end where it goes into the wall there is nothing visible holding it up. Because we can't see anything now (and knowing that something considerable has to be holding it up) tells you that the support post for that side is built into the wall. It's highly unlikely that the wall was ripped apart to put a post into the wall at a later time. In a case where something like this is added after the fact, a post is usually added to the wall that you would be able to see.
Another indicator of original would be the writing on the lumber itself. Weyerhauser hasn't edge printed their lumber like that in 25 years so it has definitely been there a long time. How old is the house?
