Do I need wall sheathing if I am using StuccoBoard?
hodag
Omaha, NE
Getting closer on starting the framing for the new garage. We are planning on using the 4'x8' sheets of StuccoBoard for the siding so that it matches the house. Do I need to use the standard OSB or plywood sheathing or can I put the StuccoBoard straight to the studs? Can I still use vapor barrier if I dont use sheathing?
Thanks, Hodag
Stuart in MN
Minneapolis
I'm not familiar with Stuccoboard, but most companies these days have installation instructions available on their website - take a look there and see if they require sheathing underneath their product or not.
mpraddict
Central Ohio
Are you talking about the James Hardie / Hardipanel boards with the embossed stucco surface? SOME Hardie products say they can be installed over studs. As already stated, check with the manufacturer for requriements INCLUDING stud spacing. IMHO, I wouldn't do it even if the mfr. did allow installation over bare studs. That board is only 5/16" thick, and regardless of impact strength, it will deflect a lot in the wind. Also, if you don't sheathe the building, you'll have to use some other form of diagonal bracing to keep your walls from racking.
