Do Nylocks Walk?
bayviewboom
Hi
I've been advised that new Nylocks, never removed after installation, have a tendency to walk.
Anyone out there experienced this?
Thx!
(posted on a couple other forums)
LXCam
Only if they get hot and prone to excess viabration.
Now if this has been posted on multiple forums, why in the hell does it need to be posted here too. Will this turn into a they said this, they said that thing? Or was it meant to be a warning to all of us. :p
lakeroadster
Central Colorado
Hi
Thx!
So many questions...
  • size,
  • grade,
  • torque,
  • lubricant,
  • ambient temperature,
  • maximum temperature,
  • minimum temperature,
  • bolt grade,
  • nut grade,
  • service,
  • environment
plinker
Northern Wi
My experience with grade 8 nylocks (1/4-3/8 NC in particular) is they tend to hold moisture and rust in place when exposed to weather, then you end up heating them to melt the plastic out at minimum or completely heating up the nut to remove it. Otherwise the stud/bolt tends to break off.
PoorOwner
CA
I now use a lot of vibratite vc3. Saved me some money when they specify you need to replace the bolt on European cars just because it had dry locker on it.
Supposively it is used to hold the turret of M1 tank. Good enough for me. Except they spec the upper temperature range is 165F. You would think maybe it gets that hot inside the tank parked in desert or at least after firing.
LXCam
Mine do.
I bought a few the other day, and they seem to have walked off by themselves.
They're probably hiding with my rulers and scribers :D
Prolly ran off with those pesky tape measures. That or are down at the bar hanging with those unruly razor knives.
6PTsocket
Mine do.
If you find them, ask them if they've seen my 24" rule.
scrumpy
New Hampshire Rt93 Exit 1
I do not use any power tools to run them up to snug, I think the friction heats and affects the nylon and makes them less resistant to staying in place once torqued. JMO
scrump
gte718p
Hi
Thx!
My Nylocks are more disciplined then to walk. They march in formation when they want to get somewhere.
Rick B.
East Tampa
Maybe it was posted so those who haven't seen it elsewhere can benefit from the information and opinions put forth here. I'm just sayin'. :dunno:
ovrrdrive
Central Florida
I've never had a problem with them... If something needs to stay tight and is a safety concern I'll either score the threads or spot weld the nut to the shaft. Otherwise nylock it is.
LXCam
Bud it was just exactly what I thought it was......a totall troll post. I was just being nice. My first response I deleted as I tried to give this guy the benefit of doubt, but sure as **** just like this post it was a waste of time. :lol:
These guys who come here and post some oblique crazy question as their one and only post crack me up. I just can't imagine how small your wanger has to be to think this **** is funny. But the responses cracked me up :lol_hitti
