JackOfDiamonds
I swap between summer and winter wheels on multiple cars, multiple times per year.
I was taught that jacks are only for jacking cars up, not supporting them. So I have a nice 3 ton floor jack that's reliable, but I always jack up the car, fiddle with getting jack stands positioned (and now I'm actually reaching under the car with no jack stands...), put the car on jack stands, change both front wheels, and reverse the process. Then do it again on the back.
Recently my friend told me I'm crazy for doing all that. If I just jacked the car up with the floor jack, I could swap the wheels in all of 30 seconds and without putting any part of myself under the car at all, or even getting down on the ground, which he says would actually be safer.
I do see the point that it almost seems safer not to piddle around with jack stands in cases where I'm not going under the car. After all, in an emergency you have to change the spare tire using the scissor jack and no jack stands. Only question is which is more reliable....a scissor jack on the side of the road or a big 3ton floor jack in a controlled environment...
So is "jacks are only for lifting" an overly broad rule?
