Do you leave your air compressor on?
henrysgarage
Carleton Place, ON, Canada
I do not shut off the compressor at night. I changed the pressure switch and the new one does not have a switch on it so only have the breaker, which are not designed to be an on/ off switch. I also have a ball valve near the tank but do not turn it off. I have thought of putting a solenoid in line and having it on a timer so it is only on when I elect to turn it on. Same thing for the compressor, must add these to my list. I did have a V belt break once and the comp was running for a while, luckily I was in the garage at the time.
zmotorsports
Northern Utah
I shut the ball-valve off at the compressor and drain the water seperator each night prior to locking up. I open the drain at the bottom of the tank once each week to drain any moisture from the tank. I do not turn off the electrical unless I am leaving for longer than a weekend, I then kill the circuit breaker. Mike.
