bsaint
for sure.
The idea of 1/2 and 1/4 only appeals to me as i can't imagine having three sizes in both shallow and deep! Thats alot of money spent.
& 1 , good advise.Buy the 3/8", and see how far it takes you. It's a good solid base line investment.
I suspect the more time you spend wrenching you'll see the need for the other sizes.
Try shopping the classified here at GJ, good tools, good bargains.
i also started with only 1/2 drive impact sockets.
it worked for a while, but now im gonna be buying better 1/2 stuff
At the risk of derailing a thread, what seems to be the consensus on this? I would think that since you can use an impact socket on a ratchet, it would make sense (in a way) to buy only impact sockets. Did you mean that you're buying better impact sockets? Or that there's something even better than impact sockets?
I started with all three ratchets (1/4 - 3/8 and 1/2), bought those from a hi-quality brand.
Started to buy sockets and extensions 2-nd hand, flee-market, ... until I got some good money for getting hi-quality sockets.
Now I've got about everything I need (socket-wise, of course ;-) )
Get the ratchets first, you'll appreciate those much more than a mere extension or socket.
Also, 6-point sockets are usually better than 12-point when talking cheapo-sockets.
Like anything else, you don't need them till you need them. As others have stated, anything 3/4" or 19mm on up are best handled with a 1/2" drive. Get under a car or truck, especially an older one that's been exposed to change of seasons and you'll encounter what we refer to up here as a "Michigan welding job." Fasteners and threads rusted and coated with dirt & salt. That's when a 1/2" pays for itself. On the other end, with as much plastic and aluminum used in vehicles these days, a 1/4" drive will save you from yourself. Even if you're careful with a 3/8", crank down a little too much in plastic or aluminum and you've got grief. A 1/4" by virtue of it's smaller size prevents getting too muscular.
It's kind of a Catch-22. The more you work on your own cars, the more money you will save. The more you work on your own cars, the more you need to spend on tools.
I never even thought about trying to take off a lug nut with a 3/8" ratchet. I couldn't imagine that it would be very easy. 1/2" is a must.
I could see trying to get away with not using a 1/4" ratchet and get an adapter instead, but it'd be more trouble than it's worth since 1/4" isn't that expensive.
don't most cars come with lugnut wrenches in the USA![]()
^^^I would assume that only people who don't wrench for a living would ask this question.
That was a dumb question
So.....does that mean the use of 3/4"...or 1", or 2 1/2" or 3" drive is UNHEARD of???
Is this a serious question? Do you loosen/tighten wheel bolts with 3/8" stuff?
As a mech, i couldn't do a whole lot without 1/4" and 1/2" stuff. I even have 3/4" stuff that i use fairly often.
I think a better variant of this kind of thing is looking for ways to get away from duplication. It's all come up before, but things like owning only 1/4" + 1/2" or 3/8" + 3/4" or having impact only in certain drive sizes.
