Does anyone else make this Snap On tool?
kythri
Lebanon, OR
Any reason a 7/8" flare nut crowsfoot on a flex-head bent-handle ratchet wouldn't accomplish the same thing?
stage20
pcola FL
id pass on that OTC version. the stock photos make it look cheap as hell. the link above for the CAL one seems more heavy duty and also more cost effective
Stevenn1
USA
I have the Snap on one. It's awesome. But if u don't do O2 sensors a lot there are some cheaper alternatives. Also, Autozone had an identical one, I don't know the brand or quality tho.
shockwave
Marietta,ga
Schley makes there version for blue point that I use they do offer a cheaper option but unsure of brand
I do like older snap on open/flare wrench in 7/8 for oxygen sensors I believe it's the rxs line but sadly not made anymore have to get used thru eBay I believe part number is rxs28
WhiffySpark
If you honestly think the great neck / cal van is the same... we've been through this before :lol:
anndel
Hawaii, USA
I have the Snap On version and it works well. Only used it once but I figure I'm going to use it in the future. Got it brand new from Ebay for $75 with shipping.
454ragtop
Carver, MA
Link? As someone who owns tools from most all manufactures would like to see the difference other than the obvious Snap On is the best. Might/probably is the best, but what's the down side to the one without SO etched in the handle?
1cargarage said:
I have had decent luck with Lisle tools. Some are fantastic, some are awful.
^ You could fairly make that statement about any brand of tools out there - present day or in the past.
Cal-Van was a buy-out line for us - it wasn't something we bought direct - it had to be special-ordered from a local warehouse distributor. I don't recall any issues with any of the stuff (or from Lisle or K-D) other than some of the items were spendy, but that was usually in comparison to schlock lines like Wilmar.
Something else that you have to bear in mind is that those companies do a tremendous amount of outsourcing - a good portion of their product lines (from all three of those I mentioned above) - was made by somebody else and they just put it into their own packaging (that was particularly true of K-D.)
454ragtop said:
"...would like to see the difference other than the obvious Snap On is the best."
^ Me too, especially after clicking both the links above and seeing photo images of what appears to be the exact same item on both web pages.
But then, as with the snap-ring pliers discussed in another thread, there will always be those who will insist the one with "Snap-on" stamped on the handle is better quality than the exact same item with a different brand name stamped on it.
I believe the term is "dogma". :lol:
Mr_B
Reading
I wouldn't invest that much in one O2 tool, better multi piece kits available and some good quality individual tools at 15 to 30 bucks if have a good look .
I achieve similar function to the snapon with a O2 socket with a offset 3/8 drive flange which I use with breaker bar or ratchet .
Super Mech
Bronx,NY
If you do a fair amount of O2 sensors get the snap on. I have it and have seen some knock offs of it. The Snap on is a really well made tool. The split hex is very ridged meaning that it won't spread on a stubborn O2 like a cheap tool will. The last thing you want to do is round off an O2 that is a PIA spot.
Eric29
Western NY
I bought a cheap version of this tool:
https://www.amazon.com/dp/B002GQAYVQ/?tag=atomicindus08-20
Useless. There was no chance that I could get enough pressure with this to remove the oxygen sensor so I just heated the sensor to remove it. I would get the higher quality tool if I were you. Not all sensors are in a place where they can be easily heated. If the Snap On has a proven track record, I would get it. You need a lot of torque to remove these sensors.
T45
Mr_B
Reading
^ I have 2 like that in 3/8 and 1/2" drive, not snapon but they work real well and very versatile in where can fit and how position wrench bar, my 4pc kit set was about 65 bucks and done a few sensors over decade I had it with no drama ...
pablo94sc
Memphis
I found this thread looking for what you guys use. Seems a lot of you are getting stuff that won't fit on an O2 that's inside a heat shield like a wrench, and others are saying get 7/8" when O2 sensors are 22mm. Not a big difference until you round off the flats. Crow foot sockets **** for the same reason, easy for the socket to get cockeyed abd round the flats.
Snappy is down for maintenance tonight but this looks promising -
https://www.amazon.com/dp/B002BFFH9G/?tag=atomicindus08-20
Thoughts? Seems like it'll work well for deep upstream sensors buried in FWD heat shields. Not having to remove that cover will save a ton of time.
dsmnickk90
If it's real stubborn break/cut the back off the sensor and use a deep 6pt socket
T45
The shorter the o2 socket is (ie, shallow vs deep) the stiffer it is, which means less torque-stick like flex and better change of a clean removal.
thos long ones also don't fit everywhere -- if it works for you, the go for it. in general that long socket with a slit is gonna flex (see: big cutout, long length) so better to use an extension and a shorter, stiffer o2 socket...again application specific IMHO.
thos are my $0.02
Tom.C
Just walk into autozone and buy one dude. OEM they're like 12 dollars. Same thing as pictured in op's link
pablo94sc
Memphis
Ford has a heat shield over the upstream sensor which is very deep with the pigtail, and uses 22mm not 7/8". Cutting the wire isn't in the cards as it's my only car that runs currently.
I'll give that Amazon one a try. It'll be a lot easier to return it if it doesn't work before I get crazy trying to pull the heat shield off. I can only contort so much at 40. Lol
