Does Anyone Make a Stubby Tap Set?
Josrobinson
Does anyone make a tap and die set that contains shorter than normal tap? I have to tap a hard to get to hole and my normal taps are just too long to line up perfectly. Thanks for any help in advance.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I've never seen any in all my years, but the last link that Monkey shows, looks like a short tap. I wouldn't mind having a set myself. I just wonder if they are sold on this sold of the pond?
J
Josrobinson
Thanks for the links guys. I will definitely look into those if I can't come up with a quicker solution.
I wonder why I didn't think of cutting one down. Only problem is I don't weld as of yet. I have a little flux core welder I picked up to learn on, but never got around to trying it out. I guess it'll be a nice way to learn. So just a couple of tacks will do it?
claymont
CLAYMONT, DE
Just grind a square on the cut down shank the same as the original and use a twelve point socket to drive it. If its still not short enough, grind off what's needed from the threaded end.
J
Josrobinson
Great, sounds a project I won't get to until this week. Thanks for the tips.
