So the other night I started checking my dads truck (2005 GMC 2500) over for it's annual state inspection. Found a couple of bulbs out and the rear brakes were just over the state minimum requirement of 2/32". So I removed the calipers and rotors, cleaned the caliper brackets and the rotor mounting surfaces of any rust. Today at lunch I called around to local shops and asked if they could turn a set of rotors if I brought them down. I called twelve shops and the only place that would turn rotors was a parts store with a machine shop. The eleven other shops said that they don't turn rotors anymore and that it's just cheaper to replace them. These rotors are the OE parts that came on the truck, they have been on there for 14 years and 138K miles, they have a slight amount of rust on the outer edge. The OE GM rotors are over $200 a piece for this truck, aftermarket rotors are around $75. I have never had good luck with aftermarket brake rotors so I was not going to go there. When I was in the dealership we always turned rotors and never had any issues. Why would you throw away a perfectly good part when you can spend about 15 minutes of time while charging a customer an hour labor? So what everyone was telling me to do was to toss away a quality part and replace it with aftermarket piece of ****. I have been out of the auto business for six years now, have things changed that much since then? Sorry for the rant, it's just that I don't get it.
