I have a Milwaukee 9 piece hole saw kit. I’ve heard using drill bits in sheetrock ruins the tip.
Does the same apply to hole saws?
If so I’ll buy a cheapy hole saw kit from HF.
Does the same apply to hole saws? If so I’ll buy a cheapy hole saw kit from HF.
Drywall doesn't hurt them but old lathe and plaster is super hard and will dull them fast.
Plaster will ruin a bit quickly. Drywall will dull bits more quickly than wood, but you can cut quite a bit of it before the bit is no longer serviceable.
However, if you're dedicating the hole saws to drywall use, you can touch them up with a triangle file and they'll last forever. They don't need to be all that sharp.
This!
I had dedicated hole saws for remodel recessed light cans. I didn't even realize they were dull until I went to put a light above a sink that was trimmed out in wood (between two cabinets). The blade struggled and I figured it was me, I tried getting my body in a better position - still had issues. It was then that I looked at the saw and chuckled to myself. I'd worn the thing out pretty well. You'd never be able to tell when popping holes into the ceiling.
