Doing it wrong or unicorn box?
PCustoms
VT
I'm assuming I'm doing it wrong as I can't seem to find a solution that works between the orange box and a quick search.
Need a 3 gang box that can be surface mounted with conduit. Cover needs to have at least one "decora" gang, 2 normal switches and preferably no sharp corners.
Currently have 2 "handy" boxes that is like to combine into a single switch bank.
LXCam
Stainless plates fit perfect to a bell box if so inclined.
P
PCustoms
VT
What box?
I'm not a huge fan over covers like that in this use, as I could be coming in blind/dark for the switch.
P
PCustoms
VT
Supply House has a 3-gang drawn box for $20, shipping would be kind of dumb. Amazon has a "garvin" for $15, I'm sure it's a Chinese knockoff. I suppose for a metal box it doesn't matter.
This would work. Need to decide if I have any reason to leave the 2 outdoor lights independent of each other. If not I'll combine them on 1 switch and the interior on the other. Aside from cover plate (and possibly conduit fill) everything is already on the wall for this...
P
PCustoms
VT
Well I'll be damned, depot doesn't sell them anymore. Amazon shows some.
They might, Depot search *****, yesterday I searched a SKU, of something I just bought, and it brought up something different.
My local store is a trainwreck most days.. thankfully the major reno is behind me.
mm08822
Order the "3 gang" box and surface mount raised cover online. Search RACO website for part #'s.
Or use 1 4" sq box and ****** out to a handi box.
sparky 1971
Central Iowa
So, you have three switches and one of them is decora? I figured it was two switches and a GFCI. The next thing I was going to suggest was a two switch raised cover and put the GFCI below it with a box spacer, and make it a quadplex while you're at it for looks if nothing else.
P
PCustoms
VT
Single switch for the indoor "walkway" lights to get from the entry across the garage (main shop lights are across the parking area).
Dual gang and 2 switches for outdoor lights. Swapping at least one of the outdoor lights to a timer.
Probably just going to put them both on the timer, then use the other gang for the indoor lights
P
PCustoms
VT
If you need some depth.
I think I've got it figured out now, but I guess this is the cruc of my question.
People **** on handy boxes all the time, but in an exposed location they sure look a lot more finished then a welded box.
Are the welded boxes really meant for surface mounting?
mm08822
IMO, no. You want a drawn box and matching ...................smooth, no hard corners.
Handi boxes come in drawn and welded version too.
dscheidt
Come to Chicago. This is stock stuff here, at least at the supply house. Garvin makes them. Or at least they did, before sourhwire…
sparky 1971
Central Iowa
I can get 1-1/2" deep boxes in drawn or welded but nobody stocks drawn 2-1/8" deep so, in order to keep everything matching, I use welded. Raco 189, 232, and 232CS. The CS style is only made in welded anyway and I use a ton of those in pole barns. I will admit that drawn looks nicer with a raised cover but 99% of people wouldn't know the difference. As far as handy boxes, I will occasionally use one if it's 2-1/8" deep and I've never seen one of those that wasn't welded, but they may exist.
dscheidt
Deep drawing is expensive. Garvin makes a 2 1/2 drawn handy box. See them sometimes on boilers, there's a fused safety switch that comes on a handybox cover, and the volume is nice to have. an over stuffed box, instead of a deeper one or an extension, is a sign that there are probably other problems with the installation.
mm08822
I searched raco 232cs and found Lowes carrying a raco 239, drawn, 2.125", 1/2, 3/4 ko's, but requires ordering.
Drawn 2.125 handy boxes exist and in stock at my local orange.
On the shelf is whatever keeps moving at any place these days.
Finding what you need at mom & pop shops with 1/4" of dust on it is almost a forgotten memory.
sparky 1971
Central Iowa
Nah, the CS stands for corrugated steel and is made for pole barns. The knockouts on two sides are punched a little further from the back so the conduit can come out the side and lay right on top of the ribs of the metal with no knockouts. I don't think there is a drawn box like that. The 239 is a plenum box.
There's part of the problem, I won't go to HD. Menards carries welded and believe it or not, the supply house I go to most often either doesn't carry any kind of deep handy box, or the counter guys don't know what it is but I have asked more than once and of different salesmen.. I haven't asked at the other three SH's I have accounts with, but I'm not in them often enough to remember something like that.
P
PCustoms
VT
^^^around here it's home depot or the supply house, which is closed after 4:30 IIRC.
sparky 1971
Central Iowa
I understand not having much of a choice is a problem in some parts of the country. I have accounts at four supply houses, open from 6 a.m. till 5 p.m., one is open till noon on Saturday. We have five Menards and there's nowhere in the metro area that isn't 15 minutes from at least one of them, three Lowes but none of them are in a location that is convenient with two of them being about five minutes apart from each other, and three HD'd. Orange pissed me off over 10 years ago and I haven't forgotten or forgiven them. They will never get one red cent of my money.
Brandon_oma#692
North West corner of Illinois
Cool to know. That would have made my life easier. Ended up spacing the boxes out on the walls of my shop.
AntonLargiader
Charlottesville, VA
I assume you also want the raised cover with corner screws, like the drawn 4x4s get? I'm with you... a few weeks ago I spent some time looking for that, too. No one seems to make a 3-gang equivalent of those nice drawn 2-gang boxes with matching covers. The missing part is the cover; all of the wide-box solutions either use standard plates (that mount to the devices) or the box is extra wide and gets a mudring-style cover with a standard plate on that.
EDIT: the reason might be that on the 2-gang raised covers the devices are mounted to the cover and therefore need to move when the cover is removed. There may be a limit to how many devices you really want to have attached that way, and the limit may be two. More than that, they use a different system where devices are individually attached to the box.
dscheidt
Garvin makes some. They’re not common because most places you’re putting up surface mount boxes, you can just put up another.
Snap-on_rich
3 gang masonry box with an exposed work masonry box cover
P
PCustoms
VT
I had thought about how to do this and decided that I didn't need the outside lights separate since I changed out the fixture (lost the upwards lighting that was annoying). All I needed was to grab a GFCI/switch combo cover plate.
Was out running some errands early yesterday and needed a few things at the orange store so swung through the electrical aisles, of course the friendly hack in the orange apron insisted what I wanted wasn't available, and tried to tell me it would be quicker to just change the switches (though they didn't have that cover either). For now I'll just put the timer in and leave the other switch.
Funny this does exist though, maybe I'll order one and move the single interior switch over later.
WillyBoy
Genesee valley area of New York state
I've found that at the Orange Box, it's the luck of the draw. The "kids" know very little. The older guys don't always want to be bothered. Years ago, the guy roaming the electric aisles at the store near here knew where everything was and what it did and offered good suggestions about how to solve unusual situations. He has long since retired and the replacements have never been that great.
P
PCustoms
VT
It was an older guy....
The local store *****, stocks very little. When I need anything special I'll run to the next closest store, but that doubles the drive time. Wasn't doing that for a $4 cover and a box of lightbulbs
AntonLargiader
Charlottesville, VA
They don't make the same style as the 4x4 with the cover with crushed corners. At least, I didn't see it in their online catalog. If you have a link or a PN, I'd love to see it.
P
PCustoms
VT
I had found this on Amazon, but have my doubts it's Garvin:
But never found a cover...
sparky 1971
Central Iowa
That's a three gang handy box; there isn't a cover, it would be a three gang plate. There might be a three gang handy box plate available which wouldn't look too bad, but a regular three gang plat would look awful since it's going to be taller and wider than the box.
P
PCustoms
VT
I know...
sparky 1971
Central Iowa
I know...
You did state you couldn't find a cover. There is a difference between covers and plates.
This configuration might not be too bad, at least it would be something meant for surface mounting.
Edit: wrong cover. This one and use decora switches.
