Dome, Longhandle or Lunchbox, These Boxes Are Cool!
JoCoSawdust
Eastern NC
I've been on a Craftsman dome carry box kick lately and ended up doing a bit of research using David Mahers catalog collection to help myself date the variations I run across. Since I woke up at 4AM this morning I thought I'd share what I've learned.
The "Long Handle" first appeared in 1939 with the box exclusive to the Super Deluxe amber handled set. For this reason I refer to the later boxes as "Domes". I've yet to find this box that ran from 39-42. (Forgive the thumbnail clips, I've yet to figure out how to make pictures big on this thing).
The Domes appear after the war in 1946 with four variations. The smallest, measuring 19.5 long (as all the domes do) is 6.25 wide by 6 high (small box). This is the smallest dome ever offered. It has two fixed metal plates to allow the insertion of a padlock. The next two sizes, 7x7 (medium box) and 8.5x9.5(large box), are unique in that they have a cylinder key lock incorporated into the handle of the removable tray. The lift out tray also has 3 socket trays that clip to the edge of the tray itself. There's a fourth dome that's not pictured. It measures 10x12.5 (extra large box). It lacks the removable socket trays and has "the same construction as other boxes". Does that mean it has the center lock or the pad lock bracket? I've never seen one so I don't know. EDIT: Yes, the largest of the dome boxes does indeed have the center lock feature. I still don't own one but I've seen one that another collector has. None of these boxes ever appear again in later catalogs. The small and extra large boxes disappear and the medium and large boxes loose the center lock feature. I suspect the center locks (and the removable socket trays) were left overs from the pre-war Super Deluxe box.
In 1947 and 48 there's only two dome boxes offered. This is the first year of the cantilever dome. The medium box is offered as well, this time without the center lock. In its place are two fixed metal plates to attach a padlock.
The same two dome boxes are offered in 1949 but the fixed padlock plates are replaced by a more conventional hinged hasp. All dome boxes will continue to have the hinged hasp through the end of their run in 1957.
The cantilever dome remains unchanged (hinged hasp) for the rest of it's run (57). The lift out tray variant continues to be offered but they seem to bounce around in size between the medium and large box. They never offer both sizes in one year, it's one or the other. At some point in time the lift out tray goes from gray to red. Impossible to tell when due to the black and white catalog images.
The only time a dome box is offered as part of a tool kit is 1955-57 when it houses the 3/4" drive set. I don't have a Circle K or BM ratchet for reference so I don't know if one of those will fit in a 19.5" long box. Can somebody give me the length of that ratchet? If it won't fit in that size of box, that's another larger variant of box that's out there. EDIT: The 3/4d ratchet does fit into a standard size box albeit a bit awkwardly. It has to be place diagonally in the main compartment. The only difference in the box pictured below is the tray. The tray has larger partitioning for the 3/4d sockets. EDIT: I have to correct myself, a 60pc set was offered in 1952 with a dome box. My set should have ratchets that are sans the decorative bit on the neck, that'll be corrected one of these days. I'm apparently not smart enough to insert the pics here so...they're at the bottom of this post.
55-57 3:4D Dome.jpg
All catalog listings describe the paint as "gray finish" or "machinery gray finish".
Considering there's NOT a specific dome box for the 3/4" drive set, I count 9 variations of domes. If choosing to call them long handles I would think you'd have to bump the count up to 10 to take the original Super Deluxe box into consideration. EDIT: As mentioned above, there IS a specific box for the 3/4d set, the only difference being the tray. I stand by the count. 4 boxes in 1946, 2 "oddball hasp" boxes in 47 and 48, 2 hinged hasp boxes from 59 to 57 and the 3/4" drive box for a total of 9 physically different dome boxes. Considering the paint change from wrinkle gray with gray tray to hammered gray with red tray (somewhere around 53-ish?), one could say there's 11 different dome variations out there.
I have one stashed somewhere in my junk. Never thought much about the variations other than I knew there was one with the trays. Great info.
A E Numan
Portland Oregon
Hear,s one Iv had for some time now, the mechanism for sliding out the drawers is kind of delicate but work's.
3jakes
South Central PA
Lugz alerted me of this thread after I posted this box in the garage sale thread.
If I read your info correctly, this box dates 1947-48 as it has the "sort of a latch" that can accept a pad lock.
I see that the hangers for the tray have corresponding dimples that nestle the tray's "feet".
Searching on ebay, I see them referred to as Dome, Longhandle or Lunchbox as well as Tombstone, correct?
P1010001.JPGP1010003.JPGP1010004.JPGP1010005.JPGP1010006.JPGP1010007.JPGP1010008.JPGP1010009.JPG
ed4banger
Virginia
Thanks for the research and post. I do have a couple domes including a cantilever. I believe I have two of the early long handles, both crackle finish, but one is black which perplexes me a little. Been assembling a second amber set in it, but just not convinced the ambers ever came in a black box.D7I_2373.jpg
J
JoCoSawdust
Eastern NC
3jakes...yup, yours is a 47-48 catalog version. As with all things Craftsman, I'd say there could be a bit of plus/minus to the actual date of your particular box but the catalogs are as close as we'll get. I'd love to know the deal with the white paint splatter on so many old tools and boxes. It's almost as if the old timers bought a new box/tool/machine, brought it home, took it out the their shop and baptized it with white, oil based paint that would be virtually bulletproof and impervious to any and all paint removers 70 years down the road. Your box is in great condition, with the tray, nickel plating intact on the handle...great find! And yup...all sorts of nicknames for these things.
Ed....damn...TWO early long handles????? Great stuff. The black crinkle paint doesn't surprise me a bit. I can't find any evidence that those tool boxes were ever sold as a stand alone item so I'd bet the farm it came with ambers in it. Fantastic bookends!!
I need to go back through this thread and edit it a bit. I know there's probably a mistake or two along the way that I've since cleared up. I've yet to find the 1946 big boy...12"x12" end measurement. I think it was so big (honestly too big for a hand carry box) that they probably didn't sell many. I know of one in captivity, missing a tray and spray bombed but hey...when you're an endangered species you can have some flaws.
LesserSon
PA USA
Isn’t that the truth!
My early childhood memories of my grandfather’s home shop (which had been my great-grandfather’s before him) include multiple, open oil paint cans, some with brushes sticking up out of the by-then cured contents.
I think since it was used on virtually everything - indoors and out, and since oil paint cures so slowly, they just let it sit around open, touching up things as it was needed. Inevitably, spills happen.
Also, there is a sort of stigma to a pristine tool (or box): “do you ever use that princess?” A suggestion that you don’t actually work, or that you care more for the tool than for the work it can accomplish. Inadvertant spatters tend to refute that criticism and personalize the object for identification if disputed.
J
JoCoSawdust
Eastern NC
It's not every day that a new piece of verified information falls in my lap regarding anything Craftsman. Another collector was kind enough to draw my attention to this 1945 Christmas catalog clip showing the debut of my favorite tool boxes. If you read the fine print, they are "Available after November 15". That's about as definitive of a "from" date as we're going to get with a Craftsman item. Thanks Floyd!!
J
JoCoSawdust
Eastern NC
Since I'm here, I believe I posted this box over on my shop tour thread but it belongs here as well. For quite some time, I was missing only one variant of the long handle boxes from my collection; The Great Kahuna from the above 1945 advertisement. No illustration of it in this 45 clip nor the 1946 catalog, only a description for 99 N 06502 and it's dimensions of 19.5x10x12.5.
I finally found one while perusing eBay one night. No dimensions for the box listed and nothing to compare it to. The expanse of the side panel in relation to the 3 ribs and the perceived height of the "dome" gave it away. The Great Kahuna!
I picked it up for a quite reasonable price even with shipping (much less than I was willing to part with to complete the collection).
Of interesting note: The other 3 long handles of the debut year had removable socket trays. This box is listed as socket trays not included. What it does have is one integrated socket tray built as part of the removable tray, a treatment we'd see in later Craftsman carry boxes.
The last pic is the Kahuna sitting by the smallest of the long handles. Kahuna 1.jpegKahuna 2.jpegKahuna 3.jpegKahuna 4.jpeg
