Done with jackstands
chicane
Central Virginia
I am done with jackstands. Ideally I would like to have a lift. That might be a ways away. Is there any other sort of system that I can use that will give me more and better access to my car's under-body and get me more leverage if I need to use a breaker bar?
franzdom
NC
Do you have ramps?
Why are you done with jack stands? Is there a chance the ones you are done with aren't awesome?
I have 2 pr of ESCO jack stands and they are awesome. I don't hesitate to get under the car if it's on ramps on one end and up on jack stands on the other.
aka Larry
Eastern, NC
Why do people keep saying their Rhino Ramps slide? I have a pair and the little rubber foot under the edge prevents mine from sliding. I've used them for 4 years with no problems at all.
rider9195
Same here. I usually put carpet underneath both ramps just in case though.
Vvmvbb
CT
I don't have the rubber feet and they don't slide. Go figure.
alan camby
South of Indianapolis, Indiana
I bought my dad a set of the 2 piece ( each ramp is 2 piece) Race ramps and they are very cool. Very light weight and are very long so even low cars can climb them without the front air dam making contact. Were a little expensive though.
Pointsnorth
Canada eh
Do you have ramps?
Those look great. What is the coo? I'm asking because I want a set, and don't pay import duty into Canada if coo is USA.
EvilWelder
New England
I can pick up my Malibu and the wifes Explorer with the liftgate on my welding truck:evil:
If I really need undercar clearance I can rig it and do a lift with the crane :beer:
EDGAR
Some ramps and some lifts. Enjoy.
Try the next one if you dare...
beerdog
Buffalo Grove, IL
I have a friend who picked up a drive up teeter-top style ramp. hold the bottom of the tires off the ground about 18in. Got for a few hundred bucks. Keep an eye on CL.
fourjeepin
Atlanta, GA
Those DIY wooden ramps look sketch to me.
I use wooden blocks on occasion. Not like shown on that diesel site though. Mine are 5 2x10s screwed together. These are not intended to be driven on, rather you jack up the vehicle and slide these under. Not as adjustable as a jack stand, but no chance of it failing.
SMKS
USA, planet Earth
Why?
You won't have much for options if you want to do a job where you remove the wheels.
k5fd89
Baton Rouge
C
chicane
Central Virginia
Try these
I drive up front then jack up rear and put second set under rear. It's not the best but it's better then jack stands IMO.
If I have to work on one wheel I support that area with jack stands and remove one ramp. Just think its more stable
How tall are they? can you post pics?
jmm
NC
I can't stand lifts. I'm 6'3" and I've never been in a garage that had lifts get up high enough to keep my back from really killing me after about an hour up under a vehicle. Never been in a really swank garage either, but that's beside the point because I built two brick ramps out in my back yard. I have the perfect amount of wiggle room between creeper, myself and my truck to do anything, and stay comfortable doing it. Cheap to boot!
jeffk14
GA
Pics please!:bounce:
trboxman
North Bend, WA
I do pretty much the same thing. Just replaced a transmission and t-case in my Wrangler while it was perched on wooden platforms.
