Mr.Nutcase
use solder?
WHY WOULD YOU USE THIS, JUST SOLDER THE CONNECTION!
the heat from soldering plus the solder joint itself make the connection brittle. vibrations could cause the joint to break. that connection will last, it's secure and water tight.
i disagree. After working on electric forklifts for years that have no suspension and lots of vibration these fail. A soldered connection done right with a low heat butane soldering iron is permanent.
i have had exactly opposite on motorcycles. either way is better than a ****-splice![]()
I wish I could take pictures that good.
Those look like good and tight crimps. I have crimpers like in your pictures. Problem is I do not have the hand force to squeeze the handles together tight enough, so that I cannot pull the wire out of the terminal after the crimp is made.
In a factory situation a press is used to make the crimp.
In the old days I would put the handles in a vise and sometimes I also even soldered them.
Then years ago I bought a Taiwan ratching crimper with a set of dies, because I did not want to pay Ideal prices. I like my Taiwan crimper.
Kind of off topic but this is some sweet wiring some genius at my work did on a cam sensor. Customer found it and he was not happy. The kicker is that the guy didn't even get in troubler for it!
<a href="http://s30.photobucket.com/albums/c308/wellstig1/?action=view¤t=gerg3.jpg" target="_blank"><img src="http://i30.photobucket.com/albums/c308/wellstig1/gerg3.jpg" border="0" alt="Turd"></a>
What do you guys think about these type pliers for making crimps around the house and on older cars? Decent enough, or total rubish?
http://www.knipex.com/index.php?id=1216&L=1&page=group_detail&parentID=1299&groupID=1319
This got my attention - was it possible that the indent should be on the brazed seam (somewhat parallel to the open barrel crimp)? Had I been doing it wrong for years? Um, no. From the 3M literature:Nice illustrations. However, the upset or impression should be made on the "seam" side of the barrel.
