Door opener help ! Pls
cvcman
Syracuse NY
Legacy 850 sometimes both sensors are lit and it works fine, other times one is blinking red and the other is off
It will go up but not down unless u hold the button on the wall unit
Wires look ok but not 100 percent
Can I bypass these sensors ?
Is this a bad sensor ?
Thank you
RoninB4
Under My House
^ This (above post) should be the first thing to evaluate. Red lights generally indicate one "eye" is not seeing the other. Clear any obstructions/spiderwebs from the eyes and clean them off.
jack stand
Lakes Region Maine
My stupid "eyes" are up at the 16' ceiling height 4" apart from each other. Never had any trouble with them. No loose infants running around here to get hurt.
signcrafter
Your eyes aren't catching each other for some reason. Either off just a bit or I've seen it where the sun will interfere with the beam, door would close just fine until late afternoon when sun was full on it and then it would have issues closing. I moved the sensors back a few inches and solved that problem.
Stuart in MN
Minneapolis
I replaced my opener a year or two ago, and the new one would sometimes malfunction like you described. It turned out at certain times of the day the sun was interfering with the sensor's operation. I took an old toilet paper tube and shoved it over the sensor to act as a sun shield, and it's been fine ever since. 🙂
Dumber than lumber
I had a VERY SIMILAR situation several years ago. But for me it was a certain time of the year.
The door would not close normally when it was cold. I ignored the issue for over a year. When I finally decided to address it I bought new "eyes". And that was all it took to get the thing to work again.
How weird is that?
Skooterj
Indiana
Swap the eye positions. One eye shoots the signal, the other receives. When the receiving eye is blinded by the sun, it cannot recognize the signal from the sender. Your receiving eye should always face North if possible(unless you live in the Southern Hemisphere)
Stuart in MN
Minneapolis
I thought about that but would have been a hassle since all the wiring was stapled in place. The cardboard tube sun shield works, and took about 15 seconds to install.
