Door sill bracing
Sumboodie
AK
Got home last night from work and someone bent the door sill on my fairly new door. Haven't even had time to paint it yet.
Going to try and fix it, how can this be changed so it's supported?
The building is 2x6 and then 2x4 purlins, so the wall face overhangs the slab.
We put a PT 2x6, but the door sill isn't fully supported still.
CraigStu
Blacksburg, Va
I take it that the brown under the door is the slab? I'd get a treated piece of whatever thickness fits under the sill and attach it w/ Tapcon screws. I use their 5/16 screws and their drill bit w/ a hammer drill. If your piece of PT is a little thicker than needed I'd just leave it that way. 1/4 or 3/8 of wood beyond the sill will be fine. You could add some construction adhesive too if you like.
Sumboodie
AK
Brown is the PT 2x6
loganb
Omaha, NE
Talk to the supplier, that appears to be replaceable. With the jambs sitting on the slab and the sill between them, cutting a couple fasteners that may be going horizontally into that sill and removing any anchors into slab will allow it to be removed from inside. Slide new one in, add anchors into slab along with liberal application of sealant
Sumboodie
AK
The 2x6 is glued on. The guy that installed it didn't want to chance hitting pex, even though I told him nothing was within a foot of the edge.
alwaysFlOoReD
Airdrie, Alberta, Canada
I bend aluminum for exterior windows, doors, posts and beams. Yes, pressure treated wood and aluminum don't get along. Takes less than a year for holes to appear. Now I wrap tyvek or similar around posts before cladding, and use stainless screws or nails.
rayra
Escaped from Los Angeles
lolz, shouldn't be anything running anywhere near an entry door.
Dent isn't repairable, but a bit of careful work with a narrow piece of molding jammed up against the underside - spanning a wide spread both sides of the dent - and striking upwards with the side of a 3# maul might straighten it some without making things worse.
And you can use a similar full width piece of baseboard molding shoved against that overhanging lip to fully support it, screwing thru the molding into the 2x6, For the long time before you get a slab in front of it.
btw, whoever put that PT boards as your sill, in contact with dirt, is a fool. Even rated for ground contact, it's a terrible idea.
And yeah, something dense and hard was dropped on it. Doesn't bend like that from stepping on it.
larry4406
Northern Virginia
Unfortunately that happens to me at the day job.
We have a "fixit" conctractor that repairs damn near everything - chipped tubs, scratched stainless steel appliances, cracked/dented vinyl windows, etc.
One of their specialties is installing a permanent metal overlay on top of the damaged sill. Their overlays are similar to these
To replace the damaged sill, you are jerking the door and frame, and basically redoing the frame.
Find an overlay.
Sumboodie
AK
Dent was fixed 6+ months ago.
i4ni
Support it with a piece of aluminum C channel or a piece of angle screwed in below it you can get at any box store in their metal assortment selection area. Whatever matches the unsupported dimension. You could use treated wood as well.
