Doorbell question
Notgrownup
Snow Hill NC
I need to add an extra bell to my "Sunroom/Backyard patio area and I want to know is it as easy as tapping into the wires that go to my current bell to another bell?
Stuart in MN
Minneapolis
It should be, most doorbells simply require a pushbutton connection and you can have more than one pushbutton connected to the same terminals.
However, check your doorbell as it may have a separate sets of terminals for front and back doors - usually the front door will go ding-dong and the rear will only go ding.
N
Notgrownup
Snow Hill NC
Good point, yes it does have 2 doors ... So I will just buy a bell and some of that small wire.
jim111
tx
If you are talking about adding another chime unit, you will need a bigger transformer than what is required for one chime unit.
Mustang51js
Haskell nj
Do you have access to the wires,you need to know how many wires go to the chime,and where the transformer is located. You can't just splice into the wire going to the chime, because you would need the second button pushed in to make the front work. You should try and get a wire from the chime to where it's all spliced,which maybe in the chime, to the location of where your putting button. This way you can have two different chime tones
cabranch47
Louisiana
I read the op question as adding another doorbell not just a button. In that case you would need a larger transformer.
The Cobbler
There should be no need for a larger transformer. One pushbutton or the other will ring the bell, it's the same amount of power either way.
normally the transformer supplied with the kit only has enough current to activate 1 chime, most cases you need a larger current transformer than what is supplied. ( think same voltage, more amps )
Yeah Im not sure where the second button came from. The OP asked about adding another chime.
Though in the OPs case we have no idea what the transformers capacity is.
N
Notgrownup
Snow Hill NC
I might look at wireless, I have a double chime 2 button unit, I just need another chime unit for when the front door button is pushed.
