double ended extension?
stricht8
i have seen an L shaped one and couldn't figure out what it was used for either.
Mickey O
Chicago, IL
I suppose they could be used in old square drive ratchets. I have a Walden socket set that cam with a double male extension, it also came with a double female adapter, I have no idea why.
Dale B
Rowland Hts , SoCal
In the old days , some ratchets came with female drives , and you pushed the male drive plug thru and flipped the ratchet over to reverse it . I have a 3/8 and a 1/2 in Cornwell that belonged to my Grandpa, and 3/4 Cornwell from a swap meet that I bought to match them , but it didn't have the drive plug. I guess i'm gonna make one out of 2 3/4 reducers back to back.... I should mention these have a hi tooth count gear , prolly 50-60 , makes them very nice and smooth.
tatra
pirate contest city
the l shapes i have seen in different configs where they were equal lenghts and offset lengths like a allen key.........either way you could put a regular extension on one end for added leverage.............
justinmc
KCMO
I have the same sort of deal.. I have a 1/4" hex L thats male/male but I also have a S/O flex extension thats 1/4" drive male both sides. I'll have to double check the part # but I couldn't figure out what it was for either however I haven't gotten rid of it yet! haha.
carpenter383
The L might be used as a handle for turning sockets, and not meant to be used as an extention.
H
hoopty388
Indianapolis, Indiana
ok so like an allen wrench there is a speed end and a torque end!
I think a ratchet does both jobs? so it's pretty much useless as long as you have a ratchet:bounce:
barney rubble
I have a 1/2" x 6" double male extension and the double female coupler. I got it with a tool box of tools I bought about 30 years ago. It also had a lot of Walden stuff in it so I quess the extension may be Waldon also I'll have to look.
glenmore
Los Angeles
I would guess you could use the "L" ones like an old fashioned tire wrench and spin it. Or put on two sockets that you tend to use most frequently.
I found this one in an old tool box with a socket just about welded on with old grease.
H
hoopty388
I would like that double female. I could put it on my double male and have a heck of a long extension.
I like the idea of using an L for spare tires. I have a set of factory bolt-on Daytons on my caddy and you can't get a tire iron in between the spokes. I have to keep socket wrench in the trunk. I'll have to get one of these or talk my dad out of his.:thumbup:
Mycosid
Those are 1930s indestro. They were unmarked at that time.
I have the same one. (without double female unfortunately)
