myredracer
I bought a Dremel 3000 kit new about a year or so ago. I've been using it a lot for restoring a car body and use a 1" cutoff wheel on it. I use it for cutting a slot in the metal before using a body saw and trimming small pieces but use it mostly for knocking down some mig welds closer after I've done an initial grinding down with a die grinder. I like the almost surgical tool feel and precision it has and it can also get to some cramped spots a 3" wheel on a die grinder can't.
The multi-speed switch burned out a few weeks ago so I bought a new OEM replacement switch. The switch failed again yesterday and I need another one. First, it stopped working on all multi-speed settings and on full speed only - same thing happened on the original switch too.
Are these Dremel tools not up to the task and only good for the occasional balsa wood project? Is it a quality issue? Can't blame it on China - they're hecho en Mexico. I use this thing daily (I'm now retired) and am kinda stuck without it. The new switch I got cost me something like $40 (Can.) and I hesitate to get another one that's gonna burn out again in short order. There is a 2 year warranty on this tool but I got it on Amazon or ebay and can't find the purchase history on it anywhere, pffft.
What about perhaps getting the Dremel 4000 "high performance" model? Would it be any better? Or is there another brand of similar tool that is more durable? The 400 has a 1.6 amp motor and the 3000 a 1.2 amp one. I never have a problem with lack of power. I don't seen anything else in the description that indicates the 4000 is tougher.
I don't need multi-speeds and always run it on full speed. What about bypassing the switch and putting an external switch on the power cord? The field coils have 4 connections and don't know if they are wired in series or parallel.
Thanks!
Thanks!
