Drill Bit Set 9/16-1"????
karoc
Hemphill Tx
Guys I have a need for this size drill bit set so I went shopping on the net.Finding an american made set new will cost 250.00 and thats just way out of my league for those once in while moments or needs.But when that need comes up I want the drill bit to be sharp and work,but the cost.So if you have/had a need for a set of this size what did you go with,links and where's would be nice to know?I did look on the auction site and they run about 50.00 bucks so to me that's kinda an indication of quality unless someone here has pick up a good set of ebay please let me know what you went with?Thanks guys for some guidance.
Strouty
Southern Maine
I will say that I only use them in a drill press or milling machine, so if you are going handheld, they may not hold up as well.
6PTsocket
As much as it pains me to say it, Harbor Freight ones have held up well.
Amazingly, for me too, but I have not used them a whole lot. Mild steel, drill press, go slow, lots if lube...no problem. We are talking about the Silver & Demming set, right?
MattT
Hand drilling is gonna be hard on any bits, and the operator, in that size range. Unibits are a better option if the material is 1/2" thick or less.
K
karoc
Hemphill Tx
Be using them in tail stock and in small mill,so good to hear that HF will work.I have the small set of Norseman bits is fantastic which their 4 piece set is a descent price but the 8 piece is pushing the limits of common sense in my case.
Rabid Badger
MushCreek
Upstate South Carolina
I bought the cheapest set by 1/32's that I could find on ebay, and they work just fine in my mill, as long as you use conservative speeds and feeds. For the few times a year I need them, they work.
