Something else for consideration:
$279.00
These have a 5-year guarantee, tool and batteries. Also, these batteries are lithium manganese, instead of lithium cobalt technology.
http://www.toolup.com/milwaukee/0824-24p.html
MILWAUKEE 0824-24P
V18 Drill + Free Impact Kit
MILWAUKEE V18 Cordless Hammer Drill / Driver Kit w/bonus 0881-20 Impact Driver
1--V18™ 1/2 in. Hammer-Drill Kit
High Power Motor delivers 550 in-lbs. of torque
Battery Pack can be installed from the front or rear to fit in tight areas
V18™ Lithium-Ion Battery weighs 1/2 lbs. less than comparable NiCd batteries and offers up to 50% longer run-time
V18™ Li-Ion 3.0 Ahr Batteries for long run-time vs 1.5 Ahr
SPECIFICATIONS
Voltage 18 DC
No Load Speed 0-450/0-1,700 RPM
No Load BPM 0-7,200/0-27,200
Torque 550 in.-lbs. vs 450 in. lbs.
Chuck Type Keyless, Metal
Reversible Battery Yes
Spindle Lock Yes
Clutch Settings 24
Capacity in Steel 1/2 in.
Capacity in Wood 2-9/16 in.
Length 10-5/8 in.
Tool Weight 6.2 lbs.
2-V18™ 1/4 in. Hex Mid-Size Impact Driver
All-Metal Gear and Impact Mechanism for extended heavy duty use
High Torque for fast driving and fastening
Built-in LED illuminates dark work spots
Overmold Soft-Grip Handle reduces vibration
Variable Speed Trigger for better control of the fastener
Battery Fuel Gauge displays remaining run-time
SPECIFICATIONS
Voltage 18 DC
Drive Size 1/4 in. Hex
Torque 1,400 in.-lbs. vs 1,280 in. lbs
No Load Speed 0-2,600 RPM
No Load BPM 0-3,200
Reversible Battery
Electric Brake Yes
Length 7-7/8 in.
Tool Weight 3.4 lbs.
Many good choices out there. Little differences in numbers are not something you may ever notice. Some like them, not a biggie to me. Keep looking and asking. Good luck on your search!
