Drill Press / Belt Sander storage when not being used...
wkndwar
Oklahoma City, Oklahoma
So, I'm thinking of getting into some smaller wood working projects and wanted to get a small drill press and belt sander but don't really have a fixed place to put it...
Have any of you found a good way to use these tools without them being out all the time?
I've got a small workbench I could put them on when working on a project or I was thinking of building a collapsable table to use during projects...
Anyone have this same issue or have any thoughts?
MFolks
Springfield Mo.
Have a wife or a friend who can sew,make a "Cozy" for them,it helps to keep condensation off the tools when not in use.A coat of paste wax helps,also.
ScottsGT
Lake Wateree, SC
I always found a corner to hide them in. I stepped up my wood working game and bought a floor standing drill press. But my plan is to build some pull out shelves to store all of my bench top tools and the dead space under the stairwell will be a cubby hole I can roll my table saw (smaller contractors saw) and band saw into. Hopefully my planer and jointer will fit in there as well. They are mounted on Dewalt roll around stands.
matt_i
SE Michigan
If you built them on a semi truck brake drum (heavy round metal + possibly concrete base) and a post, you can "roll" them out, on the edge of the rim for use. Then roll right back for storage.
Zeke
Not many ideas come to mind if there simply isn't any space. Even a flip top tool stand that will serve 2 machines takes up some floor space.
Any chance you can go up? If so, there could be some practical solutions.
Matt M PA
SE PA
My late father made wooden bases for these types of tools that fit into the recess on the top of small roll around tool boxes. When he used one....it just sat it on the box. When he needed the other tool....he swapped them. He used the drawers for storing the bits, sandpaper, etc...
redmondjp
Redmond, WA
Back in the really old days, secretarial desks and sewing machine cabinets had some pretty ingenious mechanisms which would secret the typewriter or sewing machine underneath out of sight, leaving a smooth top when not in use. I've always thought about doing that on one of my benches with a side-by-side grinder and wire wheel, so they can be swung down underneath and flush to the front of the workbench.
Kaizen
New England
In my old shop I built a base cabinet for specific items like my tabletop drill press. Also had some things mounted on double layer 3/4 ply so it just slid in on runners. I hated it. Found I really despise lifting and moving tools. In new shop I am planning an outfeed flip top table that will house portable items until needed. Tons of flip top builds out there. Some have two tools.
ScottsGT
Lake Wateree, SC
Anyone remember the old Craftsman bench that held three tools like this? It had a center section that had a triangular base that would hold three tools. Just Google Craftsman Rotary Tool Bench.
Can't imagine it would be that hard to replicate.
redmondjp
Redmond, WA
I bet that it utilized a rotary power joint similar to what is used in a retractable extension cord reel - if you were to only rotate the unit by 120 degrees either way from the middle tool position, you could probably get away with having all three tools stay plugged in to a power strip mounted on one side.
bherren
Tennessee
I have accumulated 3 small roll around boxes and may have a 4th heading my way. I have been wondering what to do with them. I am going to use your Father's idea. Thank you for sharing it. Brilliant!
Lynden
Southern California
Isn't Matt M's father's idea the same as the picture in the Wood Magazine article I linked previously? In the article one roll-around base is used for all of the tools stored in the rack. Your three or four roll-around boxes are going to take up a lot of floor space.
https://www.woodstore.net/Bench-tool-System-p/gr-00560.htm
AldeanFan
Niagara on the Lake
Get a B/D workmate,
Mount your tools to a piece of plywood with a 1x2 strip fastened to the underside. When you need the tool clamp it in the workmate using the strip.
When not in use store the tools under the workbench and workmate hung on the wall.
Has worked for my dad for years.
bherren
Tennessee
Yes, it is. I really like that and may consider a version of it. I do have floor space for the roll around boxes. 4 will be my limit and I have more than 4 tools. So, I will either make them where they can hang on the wall or a cart similar to what you posted.
W
wkndwar
W
wkndwar
So here is what I put together this morning with the link from above, although I haven't decided what I'm going to do for the sides and the door yet. Casters are on order from amazon.
I made the shelves the same size as the cut out on top so I can mount the tools on the shelves and slide them into the base on top when needed.
