Drill press cabinet
Scottishross
Right a have very quickly knocked up a cabinet for my drill press to sit on
It's not perfect it's only held together by a few screws
The question is do I put it this way
Or
S
Scottishross
the drill on the cabinet
I'm leaning for the second one for some reason don't know why
nine4gmc
Dallas
I like it up against the bench for extra stability, then you could roll the tool box out the way if you need more room.
daveroy
Omaha NE
Just my $0.02
Bolt the press to the top.
Put it on wheels.
Put some cheap sheeting of some type on sides and back for rigidity.
Add a bottom shelf, and maybe a couple of shallow drawers.
Now it mobile, so where you place it is much less critical, and you can keep all your bits, disks, drums, etc. all on the cart. Add your hand held on the bottom shelf and you have one central location for all your hole making stuff.
P.S. even without any of these changes, GOOD JOB!
S
Scottishross
I'm not keen on the wheels idea basically when drilling something it could be on a uneven surface if a pull the cabinet out onto the middle of the floor
The floor looks flat doesn't mean it is plus there is a few bumps on the floor too
But I am planning on a drawer and doors too to use up the whole space
S
Scottishross
A is the box all the time but the wooden shelfs I'm planning on scrapping anyway
As for the drill I just brought it so a will prob use it as much as poss
kbs2244
This is how I did mine.
This is from a "tanker" style desk. but with some reinforcement I would use the newer black/wood top style.
The drawers are great for storing drills and such.
It is on HF casters so I can stash it out of the way until I need it.
(I think casters are somethin HF does well.
They have a spoked, iron wheel with a rubber tire that is apx 5" dia.
That I use a lot.)
S
Scottishross
This is the process so far I'm planning on fitting 5 Stanley sortmaster junior boxes into or between the legs of the cabinet
G McKay
In the garage in Bremerton
Wow!! That looks awfully short to me. I built my drill press bench high enough so that the drill bit/chuck was about eye level. It's a lot easier to have the handle up about eye level than to have it so that you have to bend over to use it. Plus, you will want to see what the bit is doing while you are using it. You might want to make it a little taller. But that's just me............:dunno:
