Concur,
Albrecht chucks are both easier to use, and grip the drill better. than will a Jacobs chuck.
One often sees drills with marked-up shanks from spinning under load in Jacobs chucks, but the Albrecht will hold the drill reliably.
Keep a light pattern 'Ridgid' strap-wrench to hand, tho, as sometimes an Albrecht chuck will grip firmly enough to require the use of the strap-wrench to release the drill. (yes, I know, there are machinists who will use a Stillson pattern pipe wrench to loosen an Albrecht chuck.....and, yes, that works.....but its not a nice way to treat good equipment)
Even better, if you do enough drilling to justify the first-cost investment, are the 'Wahlstrom' chucks. They use four jaws instead of the more common three, grip very well, and are the most convenient to use.
(if you feel you really 'must' have a Jacobs chuck, get the ball bearing variety......the plain bearing version is common and cheap, but really meant only for very light duty use.)
cheers
carla
