Drill press, maybe a Craftsman? Any good?
biscuit141
Indiana
Hello All, I have been out of the drill press game for a while now, I was looking years ago for something decent, but never found it, now a friend mentioned her husband had an olde drill press in the basement he wanted to get rid of. She sent me these pictures, it looks like an older Craftsman to me, but not sure if all the pieces are there, what model it is or if this is even one of their decent models. Any advice before I go see it in person? Also, what's it worth as it sits? They said make them an offer. Thank you.tempImagelbxPe1.jpgtempImageOWe3Hw.jpgtempImage55PzDx.jpgtempImageRaedx3.jpg
FrankLee
seMI, 48317
That is a mid-'50s Craftsman 100, model 103.23140 or 23141.
IMO, it is in terrible condition.
  • The feed hub has been removed and the handle rods were welded onto the pinion shaft.
  • The pinion shaft looks replaced.
  • The return spring looks to be missing.
  • The motor is not original.
  • The motor mount is not original.
  • The motor mount rods were welded onto the replacement plate.
  • The motor pulley is not original.
  • The motor capacitor was replaced and mounted oddly.
  • The head casting was repainted over the badge.
  • The original feed stop nuts were replaced with a single hex nut.
  • The condition of the table is unknown.
  • I can't tell if those vertical marks on the quill are dirt or deep scrapes.
  • The biggie... a previous owner sliced half-way up through the nose of the head casting. A nut and bolt were installed just above the quill lock presumably to adjust quill wear.
The good:
  • It has a forward/reverse switch.
  • The feed handle knobs look ok.
Franklee, that is a part(s) machine at best. I could not sell that as a working drill press to anyone, let alone a friend.
racecougar
Missouri
Agreed with FrankLee; that drill press is in rough shape. Sure, it could be restored, but IMO, it isn't worth the effort.
exmaxima1
Midwest
It looks to me like the original handle hub was replaced with a sleeve and the handles welded to it. Much stronger than the original die-cast hub. Original pinion shaft--You can see the tapered pin is still intact so it is removable if desired.
Could be the spring is intact but the quill is locked down to show its condition. The quill lock lever looks engaged.
Looks like the owner tried to emulate the swinging motor mount from the 150-series presses. Looks ok to me.
The good:
I think it would be a decent DP at around $50-60. No need to restore, but maybe update the motor and switch. Not everyone needs/wants reverse and the reversing drum switch alone would fetch about $50 on the auction site.
exmaxima1
Midwest
