Jet JTM830 = A1S = 8x36 mill (generic description based on the table size).
These were originally made in Taiwan starting in the early 1980's. The design reminds me of a Clausing 8520 vertical mill on steroids.
The Pro:
Simple, not much to break
Wide speed range
Large table
small footprint
The Con:
Workmanship in OK, but not great
Rotating head interface greatly limits stiffness, and thus how big an end mill you can use. I felt a bit iffy with 1/2" end mills on steel.
There are lots of these mills that look the same, but they all are a bit different when you look close, such as 0.1" vs. 0.125 (yech!) leadscrew pitch, plastic vs. metal dials, with or without oilers, etc. It always made me wonder if they were made in the same factory.
Pretty high priced at $3500.
If I was going to be doing a lot of mitering of tubing, I would want something stout! The Nichols tool room miller (horizontal mill) fits that category and the bike builders seem to use them. Small footprint with 1200 lb weight. Being a very stiff design the really can take off metal. Makes the more versatile and 2x heavier Bridgeport look like a wet noodle. Can be found for less than $500. Not as versitile as a vertical mill, but if you have the space they are great small mills for hogging material. They also made vertical heads for them.
Here is a link to someone who uses one for building bikes:
http://www.francescycles.com/about-1/
Here is a link to more info on the Nichols:
http://www.lathes.co.uk/nichols/
But I would always still have a drill press......
