Drill press spindle questioj
Natas Kapas
Hello all,
I have a Duracraft 500 drill press. I want to use a newer keyless chuck with a JT2 taper, however it seems the current spindle is just shy of the JT2 size. Odd seeing how it has a Jacobs on there now.
But anyway I was wondering if spindles from similar size presses were interchangeable? I suppose they could vary a bit so long as the bearings were of size.
Any help/thoughts would be great.
larry_g
oregon
Hello all,
Don't confuse a Jacobs brand chuck with what taper might be in it.
go here https://www.newmantools.com/tech/taper.htm and see if you can find the taper of your spindle. Jt33 is a popular one.
lg
no neat sig line
ClappedOutBport
I'm sure you looked at the link, but 2 short certainly seems to fit the bill.
"JACOBS LARGE SMALL
TAPER# DIAMETER DIAMETER LENGTH"
"2 short .54880 .48764 .75000"
N
Natas Kapas
"JACOBS LARGE SMALL
What I really wanted to know was if drill press spindles are interchangeable? Say a 15" press spindle with another brand 15" press spindle, all things otherwise being equal.
Davefr
OR
If it's a generic Asian machine, then it's likely that the same machine is sold under a gazillion different brand names.
